Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-20-2002, 10:44 AM   #1
wvmiller
Profile:
Rotors for vacuum disk brakes
My 1978 31'Excella needs a brake job. Andy at Inland graciously provided the pads some time ago and I've been holding them for now. Vacuum disks stop the trailer faster than the two vehicle, and I am recluctant to dump them for many reasons.
My plan is to replace as much of the rubber as possible, replace the pads, and, if possible, get new rotors. The rotors have five lugs, and I'll bet they came off a fairly common mid-late 70's car. Does anyone know what car, or must I shuffle through the shelves of a friendly auto parts house until I (hopefully) find them. I can turn the existing rotors of course, but they will almost certainly be thinner than spec.
Te alternative seems to replace the axles. Expensive and unneeded now. Experienced advice deeply appreciated.
Bill Miller,
St. Louis
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 10-21-2002, 10:09 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Bill. I have never heard of 5 lugs on the disc brakes. They were all made with 6 lug rotors.
Why do you need to turn the rotors? It is not necessary just because you are replacing the pads. The original rotors had the dimensional spec cast into it.
If you wish to go to electric brakes, it is not necessary to replace the axles.
We have all the repair parts for your disc brake system.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 10-21-2002, 11:38 AM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Bill,
I have the '77 Excella 500 with Hydra-vac disc brakes and love their performance. The hubs have 6 lugs on them.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-21-2002, 01:01 PM   #4
wvmiller
Profile:
Duh
I stand corrected. There ARE six lugs on the rotors.
I'd still like to have new ones. Someone let the pads scrapre deep gouges in the rotors and I don't think they can be turned and not be below their minimum thickness.
78 Excella 31 CB
St. Louis
Old 10-21-2002, 05:43 PM   #5
davidz71
davidz71's Avatar
Bill,
Do a forum search for brakes, rotors or axles. I remember a couple threads where someone posted a company or two which had replacement rotors.
Craig
AIR #0078
3.73 rear end
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Vacuum Disk Brakes APB Brakes & Brake Controllers 1 04-07-2003 12:14 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
