Old 03-31-2008, 02:34 PM   #1
1959 24' Tradewind
1967 17' Caravel
San Antonio , Texas
reverse light problems
The reverse lights on my truck do not work.
When I hook up to my trailer the back-up beeper and the trailer reverse light are constanly on. my guess it's a wiring problem with the electric brake in the truck. I'm not afraid to jump in and try to fix it myself with some guidance if anyone has willing to help.
pablo is offline   Reply With Quote
Old 04-01-2008, 04:53 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
You got a back up beeper?
Thought I'd bump you back up to the top, anyone got help?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-01-2008, 05:10 PM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Pablo,
Could it be a crossed wire in the plug that plugs into the TV? If I remember correctly the center wire is the backup light. You may want to make sure the backup wire isn't crosses / toucing one it shouldn't. You may also want to check corresponding lead on the truck side with the trailer unplugged with a tester to see if that lead is hot / has current.
This is a link to a wiring schematic for the 7 way RV plug...
Marksrv.com 7 way wiring diagram page
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-01-2008, 05:29 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
First off have your ever towed the trailer with another truck and had no problem? This may help will indicate if the problem is in the truck or not.
And can we assume the trialer is wired with a standard 7 pin plug?
Who wired the truck?
2004 Excursion 4x4
Old 04-01-2008, 06:27 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Swap two wires and viola!
...When I hook up to my trailer the back-up beeper and the trailer reverse light are constanly on. ..
One of the pins on a seven-pin connector is the charge wire. It sounds like the connector was mis-wired.
I'll bet your battery only charges when you are in reverse....
Tom
Old 04-03-2008, 01:55 PM   #6
1959 24' Tradewind
1967 17' Caravel
San Antonio , Texas
Hey guys, thanks for all the feed-back...
The TV was the best...not sure if that was just about the date of the post, or what. I have seen the schematic at my local RV shop and the center pole is back-up.
And I thought all a/s's had a back-up beeper or did I mispell beaper?
The last time it was pulled by someone else there was no problem.
The idea of the batteries not charging unless it is in reverse would explain why the charge didn't last the last two times out.
So here's where I'm at right now. I have just arrived from the Dodge dealership and it turns out the truck had a bad sensor and has been replaced. the truck now haw working reverse lights.
Next will be when I hook-up to see what happens...
I'll post more info this weekend.
Thanks again to all
Old 04-03-2008, 02:33 PM   #7
1959 24' Tradewind
1967 17' Caravel
San Antonio , Texas
Carl, I get it...TV (tow vehicle)!!!
NEWBIE's what are you gonna do?
Old 04-08-2008, 05:50 PM   #8
DEITZ645's Avatar
Pablo,
Did you get your wiring problem resolved???
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 04-09-2008, 08:28 AM   #9
1959 24' Tradewind
1967 17' Caravel
San Antonio , Texas
Hey Carl,
Thanks for checking back. I was not able to get hooked up with the a/s last weekend. The plan is to check it this weekend. I'll let you know what happened.
thanks again
Sky Light Problems jalewis Roof Vents, Skylights & Fans 12 05-07-2008 07:51 PM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Tail light assembly problems DanB Electrical - Systems, Generators, Batteries & Solar 1 05-03-2007 09:07 AM
furnace pilot light problems simonhanbury Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-18-2006 10:36 PM
Reverse lights till Electrical - Systems, Generators, Batteries & Solar 5 09-11-2004 04:29 AM
