Old 01-08-2016, 03:24 PM   #1
2010 23' FB Flying Cloud
Smithville , Texas
Replacing Breakaway Switch
On the 2010 Flying cloud do the two black wires from the new breakaway switch connect to the two blue wires from the trailer I find hanging under the propane tanks?
I did not unhook the old switch so am not positive how it was hooked up.
Do I need to disconnect the batteries before I do this?
Any advice will be appreciated.
Matt & Virginia Kline
2010 FC23FB
2016 F-350 6.7 Diesel (Overkill and loving it)
Matt Kline is offline   Reply With Quote
Old 01-08-2016, 08:56 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Blue wire in the umbilical cord and under trailer wiring is typically the electric brakes. The breakaway switch connects between the blue wire and the positive side of the battery. Do you have a VOM (Volt/OHM meter)? Even a 12 volt test light would be good for the first check. Check the two wires for voltage. If one of them has 12 VDC, that wire probably comes from the battery. You can make sure it does using the OHM meter function to check for continuity between that wire and the positive terminal wire on the battery. To be totally safe and not cause any sparks, disconnect the battery before checking for continuity. A zero OHM reading, or close to zero is what you want to see.
Now use the OHM meter to check for continuity between the other blue wire and brake pin on the umbilical cord. See below for where to find a diagram. If it's also zero or close to zero OHMs, then that blue wire is connected to the umbilical cord, and therefore the brakes (assuming that your electric brakes work while connected to the tow vehicle).
If both of those checks are good, then yes, the two wires on the breakaway switch connect to the blue wires. One breakaway switch wire connects to one of the blue wires, and the other breakaway switch wire connects to the other blue wire. Doesn't matter which switch wire connects to which blue wire.
Reconnect the battery, and you're all set. Pull the pin out of the breakaway switch and it'll activate the electric brakes. But, don't leave it out too long as it applies full battery voltage and current to the brakes.
If neither blue wire has 12 VDC, there may be a fuse that has blown. That might take a bit of tracing the wires physically to see where they go.
Here's a good reference for umbilical wiring:
https://www.etrailer.com/faq-wiring.aspx
Scroll down to find the 7 PIN RV connector you have on your trailer.
Chris
Minno is online now   Reply With Quote
Old 01-09-2016, 05:34 AM   #3
Smithville , Texas
Thanks for taking the time to help me Chris.
Matt
2010 FC23FB
Old 01-09-2016, 09:29 AM   #4
Minno's Avatar
1972 31' Sovereign
You're very welcome. Did you get it connected ok? You can always PM me if you need additional help.
Chris
Old 01-10-2016, 12:45 PM   #5
Smithville , Texas
No problem at all. Usually I underestimate myself and things turn out to be easier than I expected. Thanks again.
2010 FC23FB
Breakaway Switch and Battery brud Brakes & Brake Controllers 16 07-27-2006 08:19 PM
Missing Breakaway Wire/Switch JMR Brakes & Brake Controllers 5 06-23-2005 09:18 PM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
