Old 07-16-2008, 07:51 AM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Reinstalling Jordon Ultima in my new 2008 Suburban
I replaced my 2004 Suburban with a 2008 Suburban and I need reinstall my Jordan Ultima brake controller. The wiring harness is already installed in the Suburban so all I need to do is hook up the wires and cable to the break peddle. Has anyone done this for the 2008 Suburban. Any issues.
Don
adonh is offline   Reply With Quote
Old 07-16-2008, 11:14 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have not looked at the brake pedal assembly on the 2008 Sub but on my 1997 I had to make a 2 to 1 pulley assembly to reduce the cable travel down to the one in. that Jordan has within its controller. The reason being I could not mount the cable high enough in the brake pedal arm to achieve the desired cable travel.
If this is still the case with the newer Subs you may want to do the same or the trailer brakes will come on full long before the truck brakes are fully applied.
Name:	Jordon Bracket.jpg
2004 Excursion 4x4
Old 08-09-2008, 04:04 PM   #3
adonh's Avatar
1976 31' Sovereign
Reinstalled
I have reinstalled the Jordan brake controller to my 2008 Suburban and connected the re, white and blue wires to the red, white and blue wires from the factory installed wiring harness in the 2008 suburban and then connected to the trailer. Nothing! I checked the connections with my meter and I am getting power from the red and white leads from the wiring harness. But no green light, no red numbers. I checked the fuse on the truck under the hood and it is fine.
I must not be doing something that I should have done?
Don
Old 08-10-2008, 01:21 PM   #4
HowieE's Avatar
Images: 12
I am not sure you can assume the color codes are the same between Jordan and GM. Also you should not see voltage on 2 wires.
Disconnect everything. You should see voltage on one of the GM wires, should be a heavier wire. This is the power to the Red wire on the Jordan. One of GM wires should test to Ground. This is the White wire on the Jordan. One wire should test no voltage and not a ground. This should be the wire back to the connector at the rear of the TV. This is the Blue wire on the Jordan.
This is the Jordan web page that has the connections half way down the page.
Best Brake Controller Installation
2004 Excursion 4x4
Old 08-11-2008, 07:21 AM   #5
adonh's Avatar
1976 31' Sovereign
I found the problem
The color codes of the Jordan and GM are the same, Red power, white ground and blue brakes. After doing some research back through some GM truck forums I found out GM does not connect the red power wires to the UBEC (Underhood Bussed Electrical Center), that's the fuse box under the hood. There are 2 sets of wires that are rolled up and taped off that must be found and connected to the UBEC. I found a service bulletin that said this is not a "do it yourself job" and should be handled by a Mr. Goodwrench technician. Then I found the attached document from someone on the GM truck forum who provided the complete brake controller install instruction for 2007 and later model GM trucks. It answers all the questions and provides step by step instructions and pictures.
I going to connect the two re wires to the UBEC today. and I should be back in business, I will follow-up later.
Don
File Type: pdf GMT900_Trailer_Brake_Controller_Install.pdf (1.56 MB, 2639 views)
Old 11-23-2008, 09:06 AM   #6
adonh's Avatar
1976 31' Sovereign
Jordon brake controler
Just a follow up, the Jordon worked perfectly after I installed it. But I am now getting new axles and disc brakes for the A/S so I will be needing a new brake controler that will work on the disc brakes. The Jordon does not. So if anyone wants the Jordon for their on own personal use, send me a PM.
Don
Old 11-23-2008, 12:51 PM   #7
adonh's Avatar
1976 31' Sovereign
The Jordon brake controller has been spoken for.
Don
Old 11-23-2008, 05:18 PM   #8
Don
We have had great success with the Hayes controllers, for our customers, who had disc brakes or have added disc brakes.
There are two models available, one thats good and another that's great, depending on a persons budget.
Old 11-24-2008, 08:28 AM   #9
adonh's Avatar
1976 31' Sovereign
Which one of the Hayes brake controllers is "Great" Andy?
Don
Old 11-24-2008, 09:58 AM   #10
Don
I will let you know when I return back to the office Wednesday.
Old 12-13-2008, 03:07 PM   #11
Airstray's Avatar
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton , Washington
Images: 13
Does anyone know where I can purchase a Jordan Brake Controller? I'm pulling a 26 ft. Overlander with a Ram 3500 Cummins. Thanks, Jim
Airstray is offline   Reply With Quote
Old 12-13-2008, 03:20 PM   #12
HowieE's Avatar
Images: 12
The Jordan controller has been on hold ever since Mr. Jordan sold the company, over a year ago. I have talked to them several times and it looks like they can't find a Chinese company to make them.
You might get up to date if you call the number noted on this page Monday.
2004 Excursion 4x4
reinstalling carefree awning mtnman Awnings 9 02-25-2016 12:16 PM
New TV: 2008 Suburban LT3, 3/4 ton Jeff Evans Tow Vehicles 5 07-03-2008 09:09 AM
Help Please - Jordon 20/20 Ultima JohnG Brakes & Brake Controllers 10 10-04-2004 08:58 PM
Install Jordon Ultima BC on 04 Suburban donhardman Brakes & Brake Controllers 21 10-02-2004 07:34 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
