Old 11-11-2018, 05:08 PM   #1
2008 25' Classic
Punta gorda , Florida
Recall on electric over hydraulic brakes
I recently purchased a 2004 25 feet limited with electric over hydraulic brakes which locked up on me shortly after purchase. The AS in Alachua FL. now to repair anyone experienced this? Joe
joebutler is offline   Reply With Quote
Old 11-11-2018, 05:15 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
If this trailer has sat for a long time the pads may be sticking in the anchors or piston may be sticking in the calipers.
Is it all wheels?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-11-2018, 05:39 PM   #3
white laker's Avatar
2008 34' Classic S/O
lanark , Ontario
not sure but the 2004 may have been a retrofit to e/h brakes. They may be Kodiak which are a sliding style caliper. These are subject to seizures. If this is the case you should pull off the wheels and lubricate the 'slide pins' with a silicone based grease. If they are factory originals they are probably Dexter brakes. These are a fixed caliper design with four brake pistons on each. with these the issue from sitting is rust developing on the piston sides and in the caliper bores from leaking piston seals. As requested above if all brakes locked up, you need to focus on the brake controller/pump assembly. Is it an Accubrake or a Dexter? In order to be of any great assistance we would need to know what brake components you are dealing with. Lots of info on the Forum. All the best.... Pete
Pete Crook
"Put it all behind you!"
S/OS#88
WBCCI # 8160
white laker is offline   Reply With Quote
Old 11-12-2018, 03:42 PM   #4
2008 25' Classic
Is it all wheels?
Yes it sat for a year in a pasture but the hydraulic pump continuously runs and makes a groaning continuous sound until I pull the plug out of the brake box under the forward end of the camper.
Old 11-13-2018, 07:38 AM   #5
GCinSC2's Avatar
Runs continuous, 7 way plug connected to tow vehicle or disconnected.
Groaning sound is what they can sound like while creating max pressure up to 1600PSI.
Actuator only runs when you apply brakes.
7 way plug molded or replaced? Replaced has REMOTE chance of power being incorrectly applied to brakes. And that’s a BIG IF.
S/OS #001
Old 11-13-2018, 07:45 AM   #6
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
If yours has the factory installed E/H system (shown below), they should be rebuilding at no cost, right?
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 11-13-2018, 08:37 AM   #7
GCinSC2's Avatar
I had the actuator recall test performed and at that time it passed. So it was not a guaranteed R&R it had to fail the test. And the test was to drill a hole and see if fluid leaked out.
Hopefully these recalls were addressed but I try to bring them up when a new owner raises a question.
And that hose looks like the original config looks good right? Now mount wheel lower trailer and suspension goes up and hose gets shorter and kinks at caliper connection.
S/OS #001
Old 11-13-2018, 09:14 AM   #8
Dearborn , Michigan
Images: 21
Exactly.
Yep. J/C did the "test" on my original Actibrake, and it passed. Brought it home, parked it in the driveway. Failed the next day (fluid leaking out hole).
Old 11-13-2018, 09:47 AM   #9
GCinSC2's Avatar
The drill here test instructions were pretty weak. Low grade images. My shop drilled thru the side of the case not thru the bottom.
It later failed and I drove home w/o trailer brakes.
Replaced with Carlisle actuator.
Decided to take old one apart. Had to use saw to cut cases apart.
Found that test drilling drilled THRU a circuit board.
Brakes are working great.
Your hose pic is poster child for that problem.
S/OS #001
Old 11-13-2018, 10:19 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Although I don’t have these disc brakes, they look to be a problem child..sitting and absorbing moisture from the air, and rusting internally....our old cars with hydraulic brakes, have to be pumped at lest a couple times a month to keep the rust away...brake fluid does evaporate and absorb water....
Old 11-13-2018, 10:25 AM   #11
Dearborn , Michigan
Images: 21
I've found bleeding is required once a year. YMMV. The fluid isn't 'out of the bottle' new, but it's not bad. Only slightly darker.
Pulling all four wheels and bleeding takes 60-90 min maybe. Yeah, it's more maintenance but I wouldn't trade it for electric drums, and it can't hurt inspecting your running gear regularly.
Old 11-13-2018, 11:10 AM   #12
GCinSC2's Avatar
Goes nicely with rotating tires and pull pads to clean anchor points and dab grease on them.
Yeah I’ve spent some time working on them, no make that learning them and fixing a design flaw (short hoses) with my own version but no way am I going to change them to drums.
I know I have brakes it’s stopping like a matched set of TV brakes and AS brakes.
S/OS #001
Old 11-13-2018, 07:35 PM   #13
2008 25' Classic
Hydraulic brake blues
Thank all y’all so much. They plan to do the drill test soon. It seems to me that the controller is defective as the hydraulic pump runs while the RV is sitting unhitched.
Comment? Joe
Old 11-13-2018, 08:18 PM   #14
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Comment? Joe
If it's an Actibrake controller, the company has been out of business for many years. You have no recourse other than to purchase a new replacement from a different manufacturer.
Brake line kit with electric over hydraulic? Or existing lines? Emittim3 Brakes & Brake Controllers 4 07-30-2018 09:35 AM
Electric over Hydraulic/disc brakes Phil Gobie Brakes & Brake Controllers 12 10-13-2017 03:03 PM
Axle swap from electric to European breaks Michael Meer 1959-69 Tradewind 0 05-31-2017 03:19 PM
Electric Over Hydraulic brakes? JimGolden Brakes & Brake Controllers 23 11-17-2005 10:32 PM
Vacuum over hydraulic brakes wayne.yl Brakes & Brake Controllers 1 11-16-2004 07:24 PM
