Old 08-22-2015, 08:47 AM   #1
1969 27' Overlander
Sun Lakes , Arizona
Rebuilding Brakes on a 69 Overlander
Hello All,
You were so helpful last time so here is another question.
I've done both disc and shoe brake jobs on autos but I have no experience with trailers. Would you recommend this as a task that someone could perform?
My second question is has anyone changed to disc brakes and would you recommend doing this on the 69 Overlander?
Thanks in advance for your support
Tony and Irene
Sun Lakes, AZ
Brand New to WBCCI 2876
and of course Huck the mutt
Redleger is offline   Reply With Quote
Old 08-22-2015, 10:56 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Drum brakes on trailers are very similar to automotive drum brakes. There are a number of You Tube videos out there.
Where auto drum brakes are activated by a wheel cylinder the trailer brakes are activated by an electro magnet. When power is applied to the electro magnet it clamps itself to the surface of the brake drum. As the drum turns it forces the shoes out against the drum in a similar fashion to that of the hydraulic wheel cylinder.
Adjustment of the brake shoes is virtually the same as on an automobile or truck with drum brakes.
Old 08-23-2015, 05:48 AM   #3
Baltimore , Maryland
You can just buy a complete assembly and change the whole thing easier and quicker than changing the pads...
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 09:37 PM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 04:56 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
