Old 09-29-2010, 06:05 AM   #1
txstreamer's Avatar
1979 25' Tradewind
Blue Ridge , Georgia
Ran new wires to brakes. Still wont work...
Need some tips here.... I had no trailer brakes on my 1979 tradewind. 25' dual axle.
Ran new wires from plug wiring to brakes. (Truck is all good - no problem there)
I have power to the wiring to the rear tires when brakes are on, I checked.
Drove a bit to test. No trailer brakes. I do not know a lot about electric brakes. Some one told me they think the magnets are no good... Any tips or ideas? Would be greatly appreciated. It is the last thing I have to fix on my 79' AS other than the dreaded polishing!
txstreamer is offline   Reply With Quote
Old 09-29-2010, 06:55 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Run one tire up on a ramp so that the other tire is off the ground on the same side of the trailer. On the tire that is raised, disconnect the two wires behind the back plate. Connect the black lead of a battery charger to one of the two wires coming out of the backplate. Spin the tire and touch the red lead of the charger to the other lead from the back plate, you should hear a clunk and the tire should stop rotating. Don't leave the red wire hooked up, just touch it. If they clunk and don't stop the wheel, it may be a matter of adjustment. There are threads posted on the forum under brakes and axles with info on adjustment. Have you pulled the wheels and drums to see of you have any lining left on the brakes?
Old 09-29-2010, 06:57 AM   #3
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi txstreamer; I trust that you have a good brake controller installed in your truck and it is preset initially. If properly preset it should apply voltage to electromagnets when brake is applied. Second, are your magnets properly grounded? If so most likely power may have been applied for a very long time in the past and electromagnets burned out. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 09-29-2010, 07:04 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
This may help. Trouble shooting guide for the magnets.
How to Test Electric Brake Magnets with an Ammeter and an Ohmmeter | etrailer.com
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-29-2010, 04:51 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - Trailer brakes
slowmover is online now   Reply With Quote
Old 09-29-2010, 05:35 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
Guess at some point I might pull a drum or 4 and take a look. That'd be a good time to replace/re-pack the wheel bearings and set up the brakes. Mine had never been set up when I did mine. All the adjusting stars were unmolested.
I test brakes with the tow vehicle and the unbiblical cord disconnected. I use a battery charger to power the magnets. Now's a good time to test the break away switch too. Mine looked like it was OEM and I just replaced it with a new one.
I don't crawl under to test the magnets. I just jack up one side, jumper the 7-way plug with a battery charger, drag the extension cords to the trailer side, spin a wheel up and plug in the charger. If the brakes work, the wheel stops spinning.
Gary
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
2 wires for brakes, what goes where? greenrig Brakes & Brake Controllers 3 10-28-2008 08:57 AM
Brake light wont work; where to start. Swat Brakes & Brake Controllers 2 07-11-2007 08:09 PM
Reverse lights stuck on. Jack wont work StAlphonzo Electrical - Systems, Generators, Batteries & Solar 3 07-04-2007 07:56 AM
How Much Work do the Trailer Brakes Do? mdeneen Brakes & Brake Controllers 8 08-13-2004 09:07 AM
