Old 07-12-2014, 09:46 AM   #1
SteveH's Avatar
Common Sense , Texas
Question replacing Actibrake with Dexter actuator
OK, I am replacing my Actibrake with a Dexter actuator, and there is a wiring question that I have because the Actibrake uses an additional wire to the unit that the Dexter does not use. (Actibrake has 5 wires going to it, and the Dexter only requires 4)
It is a brown wire that has 12 volts on it, and the Actibrake information that I have says it goes to the brake-away switch, but even with it disconnected my brake-away switch has power, and sends signal to the Dexter actuator when pulled.
What did you do with the brown wire, if anything? Thanks.
Regards,
Steve
Dexter E/H Actuator to replace ActiBrake Actuator nickmeloy Brakes & Brake Controllers 32 10-22-2014 08:58 AM
Colonial Airstream Dexter Actuator Install craftsman Brakes & Brake Controllers 0 06-18-2010 11:23 AM
The New Dexter Actuator thecatsandi Brakes & Brake Controllers 1 04-13-2010 12:53 PM
Dexter actuator ? richnritab Brakes & Brake Controllers 20 07-23-2006 12:25 PM
Dexter E/H Actuator Buttercup Brakes & Brake Controllers 17 05-25-2005 09:00 AM
