Old 05-23-2010, 09:06 AM   #1
mandolindave's Avatar
Prodigy operation survey
Do people use the power knob or the boost level control to change between city and highway driving?
mandolindave is offline   Reply With Quote
Old 05-23-2010, 09:12 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Seldom touch it
I never touch the settings on mine, but I have disc brakes. My Prodigy was set up at Weatherford when the discs were installed. I adjusted it about 50 miles later and haven't changed it since.
When I had electric brakes, I had to ease it off when I picked up the trailer after sitting for a while and the drums were rusty. After I got out on the highway, I would return the wheel to the previous setting. I never changed the setting from town to country.
John W. Irwin
WBCCI #9632
Old 05-23-2010, 09:24 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have two tow vehicles for Lucy. One has a Prodigy and the other has a P3. I do not make any changes between city and highway driving on either.
Long time towing experience has shown me that as the brake pads wear, I must in crease the power setting on the controller to get a good solid stop.
I use the manual brake lever on the controller often when slowing and stopping. This allows me to get a good feel as to how Lucy's brakes are doing.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 05-23-2010, 09:48 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the controller was set up correctly there is no reason to ever touch it. Any adjustment you do on the fly will clearly violate the correct setting and result in over or under braking conditions.
2004 Excursion 4x4
Old 05-23-2010, 09:55 AM   #5
Kevin245's Avatar
We don't adjust ours either. We use the manual lever for the first few stops to scrub any build up from the braking surfaces that may have occurred during extended periods of non use. I also use the manual lever to check trailer brake response prior to any major descent's.
Kevin
Eleanor Roosevelt
Old 05-23-2010, 11:20 AM   #6
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
For low speeds, I soften up the Prodigy using the dial. For high speeds, I dial in a little more braking. The Prodigy is one of the smoothest operating and most "real world" usable units I've ever owned.
So Long!
Bob Thompson is offline   Reply With Quote
Old 05-23-2010, 11:36 AM   #7
Great tips one and all
Please bare with my confusion. If I left my old POS controller on one setting, the brakes would lock up in city traffic or not be enough for
highway driving. I am thinking that my new Prodigy contoller has no way of knowing
how fast I am going and therefor knowing how to adjust. It must be
the whole inertia thing.
Old 05-23-2010, 11:48 AM   #8
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
never change the set up myself...
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 05-23-2010, 01:27 PM   #9
Images: 67
I'm not sure if Dave's question was for me, nonetheless, in slower city traffic I rotate the dial to reduce the intensity of the braking reaction, giving it less herky jerky. The intense reaction is un-noticable at highway speeds so, I increase the braking reaction with the dial.
So Long!
Old 05-23-2010, 02:06 PM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Since it's mounted at the bottom of the dash to the right of the steering wheel, it does not lend itself to adjusting. I set it when I got it and never have changed it. A little grabby in city traffic sometimes, but leaving a lot of space in front of me and stopping slowly solves all things except that little car that likes to pull right in front of me. That's when I use the molecular disrupter and the car and driver disappear into another dimension.
Gene
Old 05-23-2010, 06:23 PM   #11
San Diego , California
Same answer
Kevin245 uses his just like I use mine. First to get the rust off the brake drums, then on a downhill.
Randy
OB Bambi is offline   Reply With Quote
Old 05-23-2010, 06:28 PM   #12
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I handle mine the same way Bob does. In addition, I use the reverse over ride or whatever they call it, when backing. I also use the boost feature on steep down hills.
Regards,
Ken
Old 05-23-2010, 08:19 PM   #13
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
when all else fails....
we're a really strong believer in the practice of
"when all else fails (and hopefully not your brakes !! ) read the instructions !!!"
presuming that you have correctly made the initial tests and adjustments, brake controllers may not need to be adjusted every time you climb behind the wheel, but they certainly should be tested almost any time you going to use it.
and there's no good substitute for mechanically adjusting a set of (drum) brakes, either.
please, put these items on your "pre-flight" checklist??
and travel safely.....
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 05-23-2010, 09:06 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if your brakes are locking up in town, they either got too hot or your controller is set too high. Warm up your brakes and slowly increase the setting until you can manually lock up your brakes at 25 MPH. Then turn it down, just enough to not lock up at 25 MPH when manually activated. This is where they should be set.
I turned my down, once, while driving on ice; I felt the trailer skid before my tow vehicle skidded. [actually, my co-pilot turned it down for me while I was driving] Other than that I leave mine as set after the skid test.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Water Pump Operation? 72safari23ft 1969 - 1973 Safari 21 12-10-2009 05:40 AM
Awning operation timmy67 Awnings 17 07-21-2008 02:32 PM
Fantastic Fan Operation Cracker Roof Vents, Skylights & Fans 11 07-10-2007 08:08 AM
Operation Freedom jremling Member Introductions 2 10-08-2006 03:45 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
