Old 05-24-2010, 02:19 AM   #15
JFScheck's Avatar
Rockville , Maryland
Images: 33
I have disc brakes - find boast ONE setting is great and just got done driving over 2,000 miles through rain, mountains (currently in the Rockies in Steamboat Springs) - the P3 is just Great!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-24-2010, 05:41 AM   #16
big_john's Avatar
1986 25' Sovereign
Gainesville , Georgia
I operate mine as follows:
1. Under "normal" highway conditions I use NO boost.
2. Under "normal" city conditions I use NO boost, but will adjust the bias on the wheel to avoid brake lockup.
3. I have found that mountain driving, particularly descent, requires b1 or b2 for me to feel comfy.
Enjoy!!
1986 Sovereign 25' CB - "Melody"
2001 Ford F-250 Super Duty 4x4 Crew Cab, 7.3L PSD
Air #41001
big_john is offline   Reply With Quote
Old 06-11-2010, 01:03 PM   #17
howco's Avatar
1970 27' Overlander
Sumner , Washington
I change the settings from light in town to heavier on the freeway, I like to feel the trailer pull me a bit under braking, that way I know it is working.....
howco is offline   Reply With Quote
Old 08-31-2013, 07:34 PM   #18
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Question for you all. A buddy has one of these for sale and I'm ready to upgrade from my "no name" controller mostly because I can't seem to adjust the dern thing. It either grabs too much or produces no braking at all. There doesn't seem to be a sweet-spot. Bottom line is it's time to get a "real" controller.
Question is this. Do you leave the controller plugged into the pigtail under the dash of the tow vehicle all the time, even when not towing? I'm just wondering if that reduces the life of the controller if it's "always on"?
The follow up question for those of you that remove the pigtail when not towing, do you have to set up the controller once it's energized for the next tow? I'm assuming here that the mechanical wheel on the side of the controller keeps the settings between trips, even when not energized.
As always, thanks for your experience and opinions.
www.nesa.org
Air No. 6427
Old 08-31-2013, 07:54 PM   #19
1989 32' Excella
Limestone , Alabama
I use a Prodigy P2 and leave the pigtail plugged in all the time, 6 years so far. When the trailer is not connected the controller goes in a low current draw mode. As soon as the trailer umbilical is connected, the controller wakes up displaying the "c" to show it is connected and ready to provide current for the trailer brakes. Hope this helps.
Steve
war eagle is offline   Reply With Quote
Old 08-31-2013, 10:48 PM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I upgraded from a Tekonsha Voyager to the Tekonsha P-3 several years ago. I Have mine permanently mounted in my center consul and never remove or disconnect it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-31-2013, 11:16 PM   #21
Southwestern , Ohio
Yes.
We have had Prodigies in two different tow vehicles for 10 years and 4 years respectively with zero problems.
Nuvite-F is offline   Reply With Quote
Old 09-01-2013, 05:59 AM   #22
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
what are the differences in the Voyager and the P3 controllers?
Bill M. is online now   Reply With Quote
Old 09-01-2013, 07:25 AM   #23
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Prodigy has been connected for 6 years; no problems.
Gene
Gene
Old 09-01-2013, 08:17 AM   #24
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Gene
Same here. I use B1 in the mountains.
Ahab is offline   Reply With Quote
Old 09-01-2013, 01:07 PM   #25
Salem , Oregon
Images: 18
Hi, simply put, A Voyager has two knobs and one LED that changes colors with adjustment; The P-3 has different modes, push buttons, and a display with numbers so you can see where it is set.
2005 Safari 25-B
Water Pump Operation? 72safari23ft 1969 - 1973 Safari 21 12-10-2009 05:40 AM
Awning operation timmy67 Awnings 17 07-21-2008 02:32 PM
Fantastic Fan Operation Cracker Roof Vents, Skylights & Fans 11 07-10-2007 08:08 AM
Operation Freedom jremling Member Introductions 2 10-08-2006 03:45 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
