Old 09-07-2003, 03:45 PM   #15
Okay --
For anybody keeping track, this week I rewired the "bargeman" connector at the trailer to a "standard" 7-wire connection.
It wasn't that straight-forward as my replacement bargeman had been "fixed up" by the manufacturer to make it easier (with non-standard wirecolors...) Add to that the Airstream's non-standard colors and it took a bit to get it right...
For my purposes the most important thing to know was that the "blue" wire from the truck needed to go to the "yellow" wire on the trailer (brakes)...only there was no yellow wire. Instead, I had an orange and a (second) black wire in the place of the yellow (found by elimination.)
I'm guessing the brakes have been re-wired at some point...
So I got it all wired up and, with great confidence, plugged in my truck and took it for a road trip.
My Prodigy reported "SH" and "OL." (Expletive deleted.)
At least I know it isn't the Bargeman :-).
I chopped the black "brake" wire and my Prodigy couldn't see the brakes (so that _is_ the wire to the brakes.) I reconnected it and disconnected the Orange wire. I still get "OL" but not as much (if any) "SH"...I slept on that for a couple of nights.
Today I took my multimeter over to the trailer and checked the Breakaway switch...by just cutting the wires, stripping them back and putting the multi-meter on "Ohms"...resistance through the switch (which should be infinite) was 0. The orange wire runs from the bargeman's break connection to the breakaway switch.
My breakaway switch has a dead short. (Different expletive deleted)
So then I crawled under the trailer, cut the wires leading into the brakes and tested resistance through the magnets. 0. I'd expect _some_ resistance through a working electromagnet. (??)
So (as usual) I have a couple of questions.
Assuming the breakaway switch has been bad for some time, am I right in assuming that the brake magnets would burn out (5-10 minutes?) and then I'd have nothing?
Should I have _some_ resistance through the magnets if they are working?
Do you suppose this explains why the battery that came with the trailer was bad (dead, dead, dead)?
I think I need a new breakaway switch and magnets. Yes? No?
Anything else I should check?
(Andy, do you have two magnets? ;-) )
Anybody have a recommendation on breakaway switches? -- I'm leaning towards the Teshonka -- since I've learned to pronounce their name :-). They have one with a brass pin for about $15. Will it hold up?
(And for anybody reading this thread who has read my repeated assertions that the brakes work fine while the trailer is stopped. Sorry. I still think I heard them, but even I have to admit the evidence is against me.)
If I can fix the brakes this week or next, I'm going camping the following Friday night. Please help me ;-)
Bob Boucneau
Denver
Bob Boucneau is offline   Reply With Quote
Old 09-10-2003, 12:24 PM   #16
hohne's Avatar
I have the same problem with a SOB (2001 Coleman Bayside) with a Draw Tite Activator II controller.
My brakes work while stopped, and even when I am backing up. When moving at any speed in foward, they actuate about 1/3 the way and then indiacte an overload.
On rare occasions, they do work properly.
I am just starting the troubleshoot...
hohne is offline   Reply With Quote
Old 09-10-2003, 07:29 PM   #17
hohne's Avatar
OK, I had some time to troubleshoot the SOB (2001 Coleman Bayside pop-up).
Pulled the Dexter Axle info and the Draw Tite Activator II documentation from the info packet we got when we purchased it new.
Got the DMM out and disconnected the battery. Pulled the trailer connector apart to verify connections. Saw from the diagram that the connector matched the documentation with the axle info.
Brake wire is blue, ground wire is white, and 12 volt wire from truck is black. Running lights are grey, brake lights are red and green. Center connector ( 7 pin connector) is unused.
Saw from my info, as the SOB is a single-axle trailer, that the two electric brakes should draw 6 amps.
Measured the resistance between the blue and white wire, and it read 2.0 ohms. 12 volts/2 ohms = 6 amps, so that resistance seems OK.
Checked the resistance between the white wire and the red, green, and grey wires. Got 2.5 ohms for the red and green wires, and 0.8 ohms for the grey wire (there are a bunch of running lights on the Coleman). This seemed relatively reasonable.
Checked resistance of the blue wire and the red, green, and grey wire. got 4.4, 4.5 and 2.8 ohms respectively. Looked OK, as it would measure the resistance of the lights in series with the brake magnets, I am guessing.
So, at first blush it does not appear to be a short in the wiring - I dunno.
I then Checked the break-away switch. It appeared to be open circuit when the key was in it,, and a close circuit when the key was removed. That seemed OK.
I left the trailer connector open, and re-connected the trailer battery. I checked for 12 volts between all the pins, and only got that between the white and black wires. The blue wire seems like it is isolated.
I crawled around, and saw that the brake wires (blue and white) is routed through the frame and axle. I wiggled both at the Y connection as it came out of the frame and into the axle. I also wiggled the connectors at each wheel. I disconnected the battery again, and checked the resistances, and they were unchanged.
I then made sure the trailer connector wires were screwed down tight. I put it back together, reconnected the battery, and looked at the truck connector.
I took it apart, and checked resistance between the blue and white wire -- it was unreadably high. I checked the wires for tightness and sprayed it with contact cleaner. I then sprayed the trailer connector with same. That looked OK. I checked the white wire and truck frame for ground. That was good.
I then checked the white wire on the trailer and trailer frame. It was good.
Ordinarily, I would hook the truck up and see if I changed the behavior at this point. However, the trailer is popped-up right now, and I did not feel like taking it down, so I crawled into the cab.
I saw that the Brake controller was not mounted firmly to the dash--it would do a fair amount of shaking. I took it off, cut the tie-wraps, unwound the black tape, and wrung out the connections. The white wire (again, ground according to the Draw Tite pamphlet) was indeed grounded, and I wiggled the connections, and they seemd tight.
I re-mounted it to the metal dash frame, and tied the wires back.
I plan upon folding it up in the next day or two and hitching it up to see if the wiggling and spraying and tightening affected the problem at all.
If it is not fixed, I plan on doing the following:
I have a friend with the same brake controller in his truck. I will borrow the truck and see if the problem repeats with his brake controller.
If it does, I will know the the fault is from the trailer connector rearwards. If it does not, I will install his controller in my truck and see if it repeats. If it does, I know it is in the truck wiring, if it does not, it is probably the controller.
If it is in the trailer, i plan on temporarily running two wires from the trailer connector to the y connections, and disconnecting the wire that runs through the frame. Then I will do the same with the wires through the axles, if that does not do the trick.
If it is still doing it, I will know it has something to do with the magnets, and will have them looked at by the dealer. Might as well have him repack the bearings, too.
I will update this thread when I work on it again...
Prodigy Strangeness... hohne Brakes & Brake Controllers 35 03-18-2005 06:47 PM
Question for Prodigy Brake Control Owner MileHigh Brakes & Brake Controllers 7 03-18-2004 04:18 PM
Prodigy price ? Model? Kistler Brakes & Brake Controllers 7 12-27-2003 03:09 PM
Prodigy Brake Controller bdbluegrass Brakes & Brake Controllers 12 04-24-2003 10:14 PM
Tekonsha Prodigy vs Voyager Silvertwinkie Brakes & Brake Controllers 11 04-14-2003 06:38 AM
