Old 04-09-2010, 02:49 PM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Prodigy controller wiring
I purchased a prodigy brake controller for my 2008 silverado. I have one in my 2005 silverado that came with an attachment harness-plug and play-no problem. On the 2008 you have to hard wire to the harness in the truck. Well.... I found my wires, connected them properly and I have no voltage on the red/black wire from vehicle which is supossed to power up the black wire to the controller. Looked in owners manual, found fuse for the brake contoller in the under hood box. Checked fuse and I have 12.6 volts. What am I doing wrong or what is wrong???? Please help, thanks
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-09-2010, 02:55 PM   #2
1986 31' Sovereign
Miami , Florida
Hate to ask the obvious but could it be a switched circuit that requires the key to be in the "run" position to work? That is how it is on mine....
Sometimes the simplest things...
mike
Old 04-09-2010, 02:59 PM   #3
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Forgot to mention that. I did turn the key on-no voltage. Started truck- no voltage.
Bruce
Old 04-10-2010, 06:57 AM   #4
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
I did eventually find the problem. On the 2008 Silverado, the red/black wire(supplies voltage to controller) is not hooke up. It is tucked up by the left fender taped to one of the harnesses going into the fuse center. Untaped and connected to the large silver post at the front of the fuse center. VOILA!!!!! power to the controller. Hooked up trailer everything is fine.
Bruce
Old 04-10-2010, 07:07 AM   #5
1986 31' Sovereign
Miami , Florida
Glad you got it squared away. Always fun to solve a mystery isn't it?
Wish I'd been of more help...
mike
Old 04-10-2010, 08:54 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That is the fused side of the panel, I hope.
Old 04-10-2010, 10:22 AM   #7
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
thanks anyway-sometimes it IS the simple things and we forget them.
Bruce
Old 04-10-2010, 01:51 PM   #8
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Here is the step by step instructions that may be helpful to others someday.
File Type: pdf GMT900_Trailer_Brake_Controller_Install.pdf (1.56 MB, 73 views)
adonh is offline   Reply With Quote
Old 04-12-2010, 09:03 AM   #9
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
adonh,
That was most helpful, thanks. I missed one of the red/black wires. am going to correct that now.
thanks again!!!!
Bruce
Old 04-26-2010, 10:25 PM   #10
1979 Argosy 27
YYC , Alberta
Having an 2007 Denali, I was sure that the Prodigy was wired for plug and play with the towing package on the truck...the previous (GMT 800's) it was plug and play.
So when I saw the wires running to the fuse box (which is done sloppily to boot) I assume the install shop did it incorrectly, and called them on it.
Guess not!
lbrownah is offline   Reply With Quote
Prodigy Controller going from NC to C and back again, why? Rivka Brakes & Brake Controllers 5 08-30-2009 11:13 AM
How to install a Prodigy brake controller Airstream 65 Brakes & Brake Controllers 1 04-07-2007 02:58 PM
Prodigy brake controller issue crispyboy Brakes & Brake Controllers 2 09-25-2006 01:27 PM
Is Prodigy the best brake controller? silverback 2002 - 2005 International 13 07-28-2003 05:03 AM
Prodigy Brake Controller bdbluegrass Brakes & Brake Controllers 12 04-24-2003 10:14 PM
