Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-29-2009, 10:17 PM   #1
Me loves da little twinky
Rivka's Avatar
Profile:  1971 18' Caravel
Fort Lewis , Washington
Send a message via AIM to Rivka
Question Prodigy Controller going from NC to C and back again, why?
i have been having trouble with my brakes , had to rewire everything because right as i was leaving on a trip (now) my pigtial seems to have died.
so i have temp trailer lights on the rig now and i just need to straight wire in my brakes.
i have wired then directly with 10ga wire one from the blue line to the brakes and one from the battery neg on my TV to the brakes.
and my controller kept saying NC (no contection) but every once in a while it would go over to C like it should and then back again??!!!
i just cleanen the conection with cleaner and put grease in it and now it is a tad better maybe, but seems to like to cycle betwen C and NC\\
what the hel is going on????
ps the controller is brand new, my wireing plug for it is just a few years old and my tires and brakes are just 5 years old or less
Rivka is offline   Reply With Quote
Old 08-29-2009, 10:33 PM   #2
Rivka's Avatar
oh and when it does say C (conected) and i use the manual slide to test it, it does go up in numbers like ti should but then quickly goies to PL (power interruption) after it goes up, huh? not sure if this is about me puttingthe brakes on or if it was just going to switch over to CL and since i was using it right then, it did PL enstead
Old 08-30-2009, 07:53 AM   #3
AirstreamGypsy's Avatar
Profile:  1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
How new is the controller? Did it work properly before? If not could it be possible that some of the wiring is different than your previous controller?
Or how well did you clean the connectors. I had difficulty once and I literally had to scratch off some of the buildup on the connectors, not just clean.
Good luck.
AirstreamGypsy
___________
AIR # 11128 WBCCI # 1818 - VAC
Charter Member FCU
CP
(Courtesy Parking)Wi-Fi
http://www.sdgraphics.net/myearthship/
AirstreamGypsy is offline   Reply With Quote
Old 08-30-2009, 08:24 AM   #4
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
You may have other issues as well. I had trailer brake magnets that were failing causing additional problems. You may need to pull the hubs and check the trailer brakes as well. Good luck...
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 08-30-2009, 09:00 AM   #5
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I had corrosion on the plug where the wiring harness plugs into the Prodigy. It caused similar problems.
Wayne&Sam is online now   Reply With Quote
Old 08-30-2009, 12:13 PM   #6
Rivka's Avatar
solution found, so far,,,
the amazing Brett helped me on a midnight call last night, we re-grounded the brakes to the trailer frame and we got the brakes working, it is still part time saying NC and we think that the brakes might be going thin so they are not giving the right feedback.
anyway i am going on my trip and right after ward i will redo the brakes, wish me luck, it should all work out,
i will update you all if i learn anything more
Lights on the Prodigy Brake Controller Bluto Brakes & Brake Controllers 6 02-02-2009 11:25 PM
First time towing with Prodigy controller. soldiermedic Brakes & Brake Controllers 9 05-03-2007 01:14 PM
How to install a Prodigy brake controller Airstream 65 Brakes & Brake Controllers 1 04-07-2007 03:58 PM
Is Prodigy the best brake controller? silverback 2003 International CCD 13 07-28-2003 06:03 AM
Prodigy Brake Controller bdbluegrass Brakes & Brake Controllers 12 04-24-2003 11:14 PM
