Old 03-27-2010, 02:49 PM   #1
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
Prodigy controler wire diagram
Just got a new TV,09 F150. I ordered a new wire harness for my prodigy controler but received wrong one. My TV came with a generic wire harness connector that plugs into TV prewired harness. But there is not a connector for the brake controller. 4 wires are labled Red/feed from battery, Blue/brakes, Green/stop and White/ground. I planed to cut connector on the harness I bought and soder wires to TV harness. Here is my problem, 4 wires on connector to brake controller are red, blue, black and white. Are the green from tv supposed to connect to the black on the prodigy connector? Can anyone help? I tried to get one from Teknosha but they don't have one on their web site.
heslinhotel is offline   Reply With Quote
Old 03-27-2010, 03:11 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
See if this helps any:
http://www.anythingtruck.com/instruc...structions.pdf
etrailer.com | Brake Controller Installation - 2009 Ford F150 Video
Old 03-27-2010, 03:43 PM   #3
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Thanks, it seems an awkward connection...Will try and see what happens. If I see smoke I'll know I didn't do it right. Karma to you..
Old 03-27-2010, 03:47 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you have time - the correct connector would be the way to go - snap in and go...
Good luck with your project - just installed one last fall and really like the way it responds.
2007 AS Wire Diagram wanted 64TrotterAtl Electrical - Systems, Generators, Batteries & Solar 2 10-09-2008 07:57 AM
wire diagram 1986 32 exella remcolent Electrical - Systems, Generators, Batteries & Solar 9 10-15-2006 02:47 PM
Do I need a Brake Controler? bridger Brakes & Brake Controllers 15 07-11-2006 02:18 PM
international 1525 furnance wire diagram BUSHKO Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-13-2006 10:21 PM
Old KH controler wiring 59toaster Brakes & Brake Controllers 10 03-13-2003 08:18 PM
