Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-22-2002, 07:29 AM   #29
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Lightbulb Breakaway switch wires
New kid,
There are indeed two conductors extending from the tongue of the trailer and there is 12 volts respectively between the two conductors.
when I short the wires, I can hear the "clank" of the brakes. Only problem is that I cannot tell if it is coming from all wheels. It seems to be coming from the rear wheels of both sides.
I have visually inspected all of the wiring at the wheels, (from behind), and everything seems to be in order. I was suprised to see yellow wire nuts on the connections but I have found the same wire nuts through out the trailer. I believe this is the manufacturer method. Any thoughts on that?
I have tandem axles. Are the emergency brakes only on the rear wheels?
I think that I am going to elevate trailer and test all brakes.
I will be splicing the wires back to the breakaway switch and I hope that is all I will have to do but could one be so lucky??????
getting closer
Smily
smily is offline   Reply With Quote
Old 08-22-2002, 09:23 AM   #30
74Tradewind
74Tradewind's Avatar
Profile:
Brake magnet test
You can test the magnets using a compass. I have to hold the compass very close to the hub but the needle will definitely move when the brakes are energized. I do this by pulling the pin out from the breakaway switch.
Remember that you should never pull the pin out from the breakaway switch while your 7-pin connector is hooked up to the tow vehicle as you will FRY your brake controller.
Ciao, Brian
www.ISellThousandOaks.com
74Tradewind is offline   Reply With Quote
Old 08-22-2002, 10:23 AM   #31
smily
"Still Working"
smily's Avatar
North and south
How ingenius,
Thanks for the tip. Especially the one about being disconnected from Tow vehicle.
Fortunately I have not actually tested the breakaway switch while the connector was in place. But that is by mere fortune because I wolud have tested it after I got all of my connector problems squared away.
I will get a cheap compass today and try the old pointer trick.
Smily
Old 08-22-2002, 06:59 PM   #32
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Smily,
The yellow wire nuts on the brake wires seem to be the standard method of connections. I would always check mine when on a long trip as they did come apart on one of my trilers once. I would think a butt crimp would be more secure, but if they have held for this long who am I to argue???
I do not know if the breakaway only engages the rear set of brakes on your model year, but let us know how the compass test works out.
Prior to rewiring the breakaway switch in I would test it with a meter to be sure it is functional. The fact that it is disconnected may be due to it not working, or working when it is not supposed to!
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-23-2002, 06:41 AM   #33
smily
"Still Working"
smily's Avatar
Pulling today
We are going to take a little trip this weekend to the lake and pull the trailer about 100 miles round trip.
This will be the first trip with all of the wiring in place.
I am going to leave the break away switch disconnected but I will probably give it a shot while I am at the camp ground.
I will get my trusty volt meter out and verify the operational ability of the break away switch.
Any way, wish me luck and pray that I dont leave my axles behind due to lock up. The trip is on flat terrain and I feel pretty safe with braking as long as I dont encounter lock-up.
Bon Voyage,
Smily
Old 08-23-2002, 08:05 AM   #34
thenewkid64
Just a member
Images: 21
In the instructions that came with your brake controller thate should be a step by step process for adjusting the gain that would cause lockup. Follow them and you should be fine.
Enjoy your trip!!
Brett G
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
