Old 05-23-2013, 09:56 PM   #15
timmaah's Avatar
1999 25' Safari
On , the road
Thanks Rich..
Makes perfect sense.
Now to find some time for even more troubleshooting.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 05-23-2013, 10:33 PM   #16
1974 Argosy 20
Kooskia , Idaho
Rather than checking voltage, or resistance, the easiest thing to do is to check the current the magnets take. Find the + 12 volt pin on the 7 wire trailer plug. Find the brake wire on the plug. Put an ammeter between those two wires. Properly operating wiring should result in 2.5 to 3 amps per wheel, or 10 to 12 amps total for a 4 wheel setup. If you are not getting that reading there is some electrical issue to deal with, from corroded wires to poor grounds. If you read the full current, then there is probably something wrong with the brake setup itself (shoes, adjustment etc.)
Old 05-23-2013, 11:32 PM   #17
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
In Post #5 Tim said he put the "lefts on the curb side".........aren't lefts supposed to be on the driver side?
So Long!
Bob Thompson is offline   Reply With Quote
Old 05-24-2013, 12:02 AM   #18
timmaah's Avatar
1999 25' Safari
On , the road
Ugg yes you are correct.. You'd think a grown man could keep them straight.
I put the lefts on the driver side / street side. The arm the magnet is attached to is facing forward.
My post 5 i stated it wrong.
Old 05-24-2013, 12:40 AM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
One thing that must happen.. you must get brakes warm enough to transfer brake material from pads to drum/disc. So, on all my vehicles, I do some 'power' stops to 'set in' the brakes. They last a long time, rarely squeal and when they do, I repeat the heavy braking and get them hot..
Usually 3 brake applies from 60 to about 10 MPH... then let cool a bit... say for a couple of miles at 60, then repeat... do this for 4 cycles.. let brakes cool down as you drive and slow normally...
Now, test as you did before...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-24-2013, 05:58 AM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Did you clean the new drums with mineral spirits and sand the magnet and brake shoe friction surface?
FWIW...I always replace magnets if they show abnormal(wedge shape)/excessive ware. They may have an internal short.
We were young and knew nothing...now we are old and everyone else knows everything.
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 05-24-2013, 07:00 AM   #21
dznf0g's Avatar
Oswego , Illinois
I got to thinking about something after I went to bed last night. You state in post # 1 that with the breakaway switch pulled you have only 11 volts at the hubs...right? AND you have only 11.x volts at the rear bumper TV connector (with the umbilical disconnected and the trailer batteries at 12.6 V?)? I am back to thinking you have two problems.
-Rich-
Old 05-24-2013, 07:36 AM   #22
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
On a drum brake the longer shoe is on the front the shorter shoe is the rear. There are no left and rights. The shoes could have been backwards to begin with. That would explain why they didn't work to begin with.
Look here:
10" Electric Brake Assembly RH, Hayes Hayes Trailer Brakes 60202703
In this photo the front is on the left.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 05-24-2013, 07:42 AM   #23
Look here:
Big shoe little shoe still applies but it's the magnet arm that determines right and left with trailer brakes, the arm must face forward.
RLC
Amanamus
"Tahawus"
Old 05-24-2013, 07:44 AM   #24
dznf0g's Avatar
Oswego , Illinois
And good supply voltages and grounds must be present for any of them to work!
-Rich-
Old 05-24-2013, 08:46 AM   #25
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Wild shot, any chance to try a different TV with your,trailer? Or try your TV on a different trailer. Purpose would be to isolate.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-24-2013, 09:40 AM   #26
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I had a similar trailer braking problem and ended up buying a new controller (maxbrake). The 5 year old Prodigy controller seemed to work some but didn't seem to put out the power of the newer controller. I borrowed a different tow vehicle before I bought the controller.
I do have a question when it comes to splicing the wires together.
The trailer has a main duplex jacketed brake wire going towards the axles. When it gets to the axles the single wire gets connected to the duplex jacketed brake wire from each wheel.
What is the best connection at the 1 wire to 4 wire (actually 2 wire to 8 wire) junction to get the least resistance?
1. large wire nuts like the factory
2. a small junction block with each wire having an eyelet soldered onto the wire and bolted to the junction block
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-24-2013, 09:51 AM   #27
Some will say solder and shrink wrap.
I have used marine connectors that come with shrink wrap on them.
I keep a selection of the heat shrink in the AS tool kit for repairs on the road, no solder needed.
RLC
Amanamus
"Tahawus"
Old 05-24-2013, 11:53 AM   #28
crispyboy's Avatar
1994 30' Excella
Bob,
Before I replaced the controller I replaced the brake wiring in the trailer. Used a 10 ga duplex jacketed wire and then went to 12 ga jacketed duplex wire out to each wheel. A terminal block was used at a point in front of the axles where the 10 ga met the 12 ga. wire. I was curious if the terminal block is a good way for this transition or should have I just used simple wire nuts.
WBCCI # 3072
