Old 07-05-2009, 12:32 PM   #1
1980 22' Caravelle
1975 20' Argosy 20
woking , surrey
parking brake: suggestions?
I want to retrofit my 1980 with electric brakes with a parking brake feature (maybe even have it double as break away safety brake). I am working on what size dexters I will need, but also need to think about the parking brake lever: Has anyone fitted these and have suggestions as to what is the easiest/best to use?
thx
Wiebe
turfclubroad is offline   Reply With Quote
Old 07-05-2009, 12:50 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Hmmmm ... parking brake? Does that imply that the electric brakes will be energized whenever parked? Not sure how you'd power them ... or that you want to add a cable activation system? Let us know what your solution is.
My parking brakes are chocks, and they work just fine.
AirsDream is offline   Reply With Quote
Old 07-05-2009, 01:33 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Seems like a lot of work,but it can be done ,you would need to retro fit the hardware from a car rearend, with the cables and an engagement lever [lever from an emergency brake mounted between seats].You would also probably have to cut out the part of the backing plate that the cable comes out of ,and weld it back in the dexter plate. Too much work,I`ll use a couple of 2x4 s.Dave
You can`t use electric ,it will burn out magnets.
easyride is offline   Reply With Quote
Old 07-05-2009, 02:24 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
A couple of wheel chucks will do a better job and cost nothing if you make them out of wood.
2004 Excursion 4x4
Old 07-05-2009, 05:01 PM   #5
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
1951 M100 1/4 Ton
This concept works great with my little Jeep trailer. You can see from the picture that the parking brake handle moves a mechanism that pulls a cable to a splitter and then pulls another set of cables to equally expand the shoes while parked. This little setup works great on this application but I cant imagine why you would need mechanical or electrical parking brakes on the Airstream?!
I use the expanding wheel chocks between my tandem wheels and they work great. A wedged shaped block would do well too
If you do consider electrical, the current draw to maintain contact would suck batteries down in no time. If you decide to go forward with the plan please post pictures so we can see the final project.
Vinnie
Name:	M100 Jeep trailer 001.jpg
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-05-2009, 05:24 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Howie nailed it again....
Checking specs on the 2010's...couldn't find discs offered...have they dropped them completely? Why.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 07-05-2009, 05:35 PM   #7
richinny's Avatar
2011 34' Classic
this system is required in parts of Europe. i'm sure someone there will have information and post it.
Ricky
Scrape crunch rip, ouch, parking accident, repair suggestions? jacarape General Repair Forum 12 12-16-2008 09:04 AM
Automatic Parking Brake CarlGeo Mechanics Corner - Engines, Transmission & More... 3 06-22-2008 09:38 AM
Should I get a parking brake on my new axle? FrenchBern Brakes & Brake Controllers 8 05-12-2007 04:33 AM
parking brake remcolent Brakes & Brake Controllers 5 03-24-2007 08:31 AM
parking brake on trailor remcolent Brakes & Brake Controllers 1 01-02-2004 09:01 PM
