Old 03-05-2010, 02:21 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
'Parking Brake' ? on 58 WT
Id not seen one of these in pictures...anyone here familiar with this setup? Its a hydraulic set up to lock the wheels in place when its parked...the handle lifts up and uses hydraulics to pressurize the wheel cylinders...Ive not seen this before...when i released the handle, it seemed pressurized, SO, i hope the wheels turn tomorrow morning!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 03-05-2010, 03:31 PM   #2
Jay.
That is not a parking brake.
Back then, like way back then, the trailer brakes were hydraulic.
They were operated by a coupler tied into the hydraulic line of the tow vehicle, using a long flexible brake line hose.
That coupler, was attached to the trailer, and held in place by the handle that's shown in your photo.
The piston in that coupler would move when the tow vehicle brakes were applied. The piston in turn, moved the shaft in the cyclinder that's mounted on the trailer. That in turn, applied the trailer brakes.
That system was outlawed when the split hyraulic systems became available on cars. The coupler was so large, that it would rob far move fluid from the rear axle brakes of the tow vehicle, to the degree that they would not work.
Parts for that system have been history for about 45 years.
Old 03-05-2010, 04:06 PM   #3
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Thanks for the info! I just had not seen that set up on a trailer...Im guessing most if not ALL have been updated if they are still on the road...More pics to follow tomorrow of the World Traveler rescue mission!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-05-2010, 04:47 PM   #4
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
I've got 2 more just like that if you want them ... they are only hooked up to the rear axle. The front axle is electric breaks.
Xbob2 is offline   Reply With Quote
parking brake: suggestions? turfclubroad Brakes & Brake Controllers 6 07-05-2009 05:35 PM
Automatic Parking Brake CarlGeo Mechanics Corner - Engines, Transmission & More... 3 06-22-2008 09:38 AM
Should I get a parking brake on my new axle? FrenchBern Brakes & Brake Controllers 8 05-12-2007 04:33 AM
parking brake remcolent Brakes & Brake Controllers 5 03-24-2007 08:31 AM
parking brake on trailor remcolent Brakes & Brake Controllers 1 01-02-2004 09:01 PM
