Old 05-03-2016, 11:16 AM   #1
1976 31' Sovereign
red bluff , California
Overload message when turn right
2005 Classic,30', 2010 GMC 2500 Duramax
Tekonsha controller. I get an overload no brake message when I turn right, returns to green when turning left and then straight.
Plug connector appears tight. Any suggestions before I roll in the dirt?
Wayne
waynedvm is offline   Reply With Quote
Old 05-03-2016, 11:40 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First thing I would do is have someone in the cab watching the controller and move the umbilical code, at the truck connection, to simulate the stress on it while making a left hand turn. I suspect there may be a poor connection in the umbilical plug
2004 Excursion 4x4
Old 05-03-2016, 01:49 PM   #3
2016 25' International
Deerfield , Massachusetts
Wayne
That sounds like the voice of experience right there!
thiel is offline   Reply With Quote
Old 05-04-2016, 04:15 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Or stop turning right!
>>>>>>>>>Action
Old 05-05-2016, 11:14 AM   #5
1992 34' Excella
1969 27' Overlander
Longueuil , Quebec
Hi, happened to me too but while backing up, and very intermittent. First, while the overload message is on, listen to each wheel if you hear a ticking sound. that would be the problem one. take if off, open it and have a look. Probably either a bad magnet or a chaffed wire (which was my case) that rubs.
sfavreau is offline   Reply With Quote
Old 05-05-2016, 08:46 PM   #6
Sainte-Julie , Quebec
Got the same problem
A wire of the brake magnet was not correctly fix and rub inside the wheel
laperrl is offline   Reply With Quote
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Information Overload!!! Duff23 All Argosy Trailers 55 07-21-2008 05:34 AM
Honda 3000is trips to overload protection on my 2004 28ft CCD kstampa Generators & Solar Power 20 07-16-2008 06:45 PM
New member with restoration overload... BambiII'64 1964 Bambi II 2 06-29-2006 12:58 PM
Prodigy indicating short and/or overload Bob Boucneau Brakes & Brake Controllers 16 09-10-2003 07:29 PM
