Old 06-04-2007, 11:02 PM   #1
Bambi Hunter
1977 Argosy Minuet 6.0 Metre
Los Angeles , California
Hoping to STOP my 6.0 Metre w/ Discovery
My '77 6.0 Metre Minuet is almost ready to hit the road. However, I have a BIG problem. My TV is a 2000 Land Rover Discovery II. First, it has the European electric harness. I have the adapter to convert to standard 4 pin, but I believe the electric brakes need the 7 pin connection. Next, I have no clue as to which brake controller to use. I've looked at the Prodigy, but the wiring for it and most others don't even mention Land Rover. If anyone has any suggestions, I'd be forever grateful. (And I'm trying to make it to the Pyramid Lake AS event.) TJ
Tim Can is offline   Reply With Quote
Old 06-04-2007, 11:40 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You plug an adapter into the 4 flat and go to a 7 pin for the trailer. The 3 wires you will need to add are brakes, 12 volt power (charge) and aux (backup lights?)
The prodigy comes with a standard wire harness. You will need to find the correct wires in your TV and tap into them. The directions are very clear as to the install. Running the brake andpower lines to the rear of your TV might not be very easy. I would not bother with the backup lights. If you do not feel confident doing this, don't! Get a professional.
Richard
azflycaster is online now   Reply With Quote
Old 06-05-2007, 05:03 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Get a Prodigy. The best controller I've ever used.
Old 06-05-2007, 11:27 PM   #4
Bambi Hunter
Got it...get professional help. That's the same thing my ex-wife told me. Thanks.
Old 06-06-2007, 04:23 AM   #5
acgypsy's Avatar
Western , Washington
tcjx4, i have a 77 minuet, my brake controller is a reese. it works well. has a digital setting for how much voltage is supplyed to the brakes, and another for how fast the voltage is applyed to the brakes. jeff
acgypsy is offline   Reply With Quote
Old 06-06-2007, 08:40 AM   #6
ScottW's Avatar
Hernando , Mississippi
I second the Prodigy vote. Works great.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-07-2007, 12:06 AM   #7
Bambi Hunter
Thanks guys. However, my first concern is the electronics of my TV. My wishful fairtale was that someone would tell me that there is a pigtail made specifically for my TV. Alas, not to be. One thing for sure...I'm taking it to a professional!
Old 06-07-2007, 07:29 AM   #8
1965 17' Caravel
1973 31' Sovereign
1987 32' Excella
Streator , Illinois
I also have a LR2 2000 . The harness and recp supplied is not something I was able to find adpt for . It connects behind the passenger side taillamp . Remove that and the connections are there. I replaced mine with a standard 7 pin . You will have to run a brake lead back from the controller as well as 12v charge line . Also most important a good ground to the socket . Also remember 188 HP and a short wheelbase . I sometimes pull the Carevel with it but not very far.
Good Luck ,,,,,,,,,,Jeff
upunover is offline   Reply With Quote
Old 06-07-2007, 09:05 AM   #9
Hamb7's Avatar
1962 28' Ambassador
Canfield , Ohio
Ha Ha
You're too funny!
Hamb7 is offline   Reply With Quote
Old 06-07-2007, 10:01 AM   #10
Royce's Avatar
Colorado Springs , Colorado
I also have a Prodigy, no direct harness available, and a '77' Minuet. We followed Prodigy directions for the install. Not an easy task but all works well. Took about 4 hours including string wires and solder all connections. The activator wire under the dash was the hardest part. Friend had to lay on his back with the wire and solder gun right above his face. What a friend! He did it after seeing me struggle with the solder gun. I came back in the next day and rerouted some of the wires. I also had to rewire the coach wire to the brakes as it had a direct short that took another four hours.
Get pro help karma sent.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 07-10-2007, 10:24 PM   #11
Bambi Hunter
Thanks Jeff,
I'm not planning to go too far. I've had it on the freeway several times already and it feels good to me. However, "good" is a relative term. I have no reference point. I'm planning to attend the Cali Rally to get more "professional" help. Thanks for your feedback.
Univolt stop running and start later brunoffrance Electrical - Systems, Generators, Batteries & Solar 6 07-04-2003 01:33 PM
Help stop the Leaks mike4038 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-17-2003 11:21 AM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 08:55 PM
