Old 07-28-2015, 08:17 PM   #1
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
On the road help needed...
Ok, we are in the maiden voyage in our AS... I have a 76 31' with a P3 brake controller...
On the first drive the P3 recognized the trailer... However I noticed on the second part after about an hour the P3 was not recognizing the trailer and showed the no trailer connected.
All the the wiring is connected and I have power to the AS when hooked to the TV.
TV is a 09 Z71 Suburban-
I checked the 7 pin on the TV and I am pulling almost 14amps - checked the wiring at the brakes and nothing is disconnected.
There are no fuses blown (the that I have found) in either the TV or the AS....
What am I missing?
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 07-28-2015, 08:20 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is the controller sending power to brakes?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-28-2015, 08:39 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have a P3. So you are saying that the no trailer connected message comes up? If so, then I would check continuity between the 7-way on the front of the trailer and the brake wires at the wheels. If you are getting voltage to the 7-way on your truck on the brake line and not at the brakes on the trailer, then something between the two is not connected. That said, if it was working I'd bet on either the connector on the truck or the trailer. I chased a bad connection on a rear turn signal for several trips. I finally took the 7-way on the truck apart and found that one pin (the small one inside the receptacle) was bent and also there was some corrosion. A simple fix. Best of luck.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-28-2015, 08:40 PM   #4
txdxrider's Avatar
They were- on the first leg- the P3 recognized the brakes- (the right one pulled a bit).
I am getting power through the 7 pin - but tomorrow I will verify the brake power lead on the 7 pin connector tomorrow. I believe this is the 5:00 pin looking into the connector...
Old 07-29-2015, 01:35 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I have the same setup you do. It's awesome. Sounds like a bad connection. I use CRC electrical contact cleaner with a nylon brush. Hope it is an easy fix.
NavyCorpsman is offline   Reply With Quote
Old 07-29-2015, 04:47 PM   #6
txdxrider's Avatar
Ok- cleaned all the contacts with electrical cleaner- and tested all the plugs and brakes, and a HUGE thanks to CWF down in Austin.. We think we have it narrowed down to the umbilical cord.... Currently checking continuity here... Will post up any other findings...
Old 07-30-2015, 06:14 PM   #7
txdxrider's Avatar
Ok - thanks to all for the assistance... After cleaning and checking everything - it only left one item.... The brakes!!!
Yes it was the brakes.... The magnet had actually sheared off during the first leg- so needless to say I was lucky to find Liberty Trailer here in Little Rock- took one off and they matched it perfectly.... The bearings were still very well greased so easy off/easy on... 5 bolts two wires and everything is as it should be- a set of self-adjusting brakes for $86 - - took about an hour and a half and the controller reads the trailer.... I'm a happy camper...
Name:	ImageUploadedByAirstream Forums1438301548.546852.jpg
ID:	244289. Click image for larger version
Name:	ImageUploadedByAirstream Forums1438301604.206438.jpg
ID:	244290Click image for larger version
Name:	ImageUploadedByAirstream Forums1438301620.945867.jpg
Old 07-30-2015, 06:20 PM   #8
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I am assuming all the other wheels were physically checked???
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-30-2015, 06:26 PM   #9
txdxrider's Avatar
Yes they were.....
Old 07-30-2015, 06:58 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sweet
Channing
WBCCI# 30676
Old 07-30-2015, 07:22 PM   #11
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Safe and enjoyable travels to you
Bruce
Old 07-30-2015, 09:49 PM   #12
txdxrider's Avatar
Thanks - headed towards cooler weather....
87 345 road side window needed Air Tube Windows & Screens 6 04-16-2015 04:57 PM
Southwest Road Trip, NM and AZ advice needed. Westfalia On The Road... 18 06-27-2013 12:36 AM
454 Carb Help, URGENT-We're on the road... gypsychris Mechanics Corner - Engines, Transmission & More... 5 10-30-2008 07:58 PM
Help - Dometic what does the check light mean - on the road with no manual! sigv Refrigerators 9 07-08-2008 04:48 PM
Going on a road trip and need help. 2bkidfree General Repair Forum 36 04-20-2008 06:29 PM
