Old 07-31-2012, 11:41 PM   #15
El Foca's Avatar
1970 21' Globetrotter
Huntington Beach , California
Originally Posted by easyride View Post
It appears your backup lights are tied into your brakes,your back-up is yellow,your brakes are blue.
For a good wiring diagram google [7 pin wiring diagram] it will show you what is what if your pigtail is color coded correctly.
Dave
Dave-
Thanks... I will try again this week...
El Foca is offline   Reply With Quote
Old 08-01-2012, 06:37 AM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Chances are real good that the wire colors in your trailer won't match the colors on a modern 7 pin connector.
Typically the wire colors are:
Green= Tail/marker
Red= Left Turn
Brown= Right Turn
White= Common/ground
Backup= ??? Could be black, but a small gage wire
The remaining 2 wires are:
The charge line and the actual brake wires. Typically these are larger gage wires. #10
If you use a battery charger. You can ID each of the circuits by connecting the black lead on the charger to a clean spot on the chassis. Then use the red lead and touch each of the wires on the UCord and note what it is.
Brakes locking up in reverse GreatPumpkin Brakes & Brake Controllers 16 08-02-2012 01:30 PM
Older Style K-H Brake Controller Rodger with a D Brakes & Brake Controllers 1 07-02-2007 09:04 PM
Capacitors on Older Electric Brakes Navigator Brakes & Brake Controllers 6 11-25-2003 01:39 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
