Old 06-23-2007, 03:42 PM   #1
1985 25' Sovereign
Lincoln , Nebraska
old style brake conversion to new style
My '85 Sovereign has the old style round magnet 10" x 2 1/4" Kelsey Hayes brakes. These were changed to a newer style in mid 1987 which uses a differnt actuator and an oval magnet. I'm going to redo my brakes and wonder if anyone has replaced the old style with loaded backer plates of the new style? What's involved? TIA
Gary
Justmeandshe is offline   Reply With Quote
Old 06-23-2007, 05:16 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you are replacing the whole works, also known as loaded backing plates, all you have to do is remove the drum, disconnect the two wires from the brakes to the magnet, unbolt the backing plate, and remove it. Installation is reverse of removal. Adjust the shoes when the drum is back on.
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
