02-27-2012, 05:46 PM
Long Beach
OEM brake actuator? 1958 Traveler
Unfamiliar with hydraulic brake systems, and the first time dealing with it. While in the process of ordering a new axle, the question came up if I wanted hydraulic or electric brakes. Hmm... Gee... I am not sure.
1. Is this a brake actuator on the tongue?
2. Is this an OEM for a 1958 Traveler?
3. Should I go with an electric brake, or stick with the hydraulic on a new axle order?
4. If hydraulic is preferred, what does everyone recommend for a replacement?
5. Do I need a different brake controller on the tow vehicle?
02-28-2012, 09:27 AM
1977 31' Excella 500
Red Rock
Never seen anything like that. It sort of looks like a surge brake. I'd replace old hydro brakes with new electric.
02-28-2012, 09:40 AM
1974 Argosy 20
Kooskia
, Idaho
I had a neighbor who had a 50's Boles Aero with a similar hydraulic setup. No parts available, no way to connect it to modern brake systems as the original used a direct connection to the tow vehicle hydraulic brakes.
So, just go with a new electric system when ordering your new axels and brakes. It will work just fine.
02-28-2012, 09:44 AM
Wise Elder
2010 30' Classic
South of the river
Yes.
I don't believe so. Airstream's two periods of experimentation with hydraulic brakes were in the 1970s and between 2005-2009. It appears to me that what you have is a breakaway brake, only, with no provisions for actuating the hydraulic system when the tow vehicle's service brake is applied. Perhaps those components were separate and are now missing.
I would suggest that you use electric brakes since none of the hydraulic components you have are suitable for re-use. While some forum members have had good results with electric-over-hydraulic disk brakes, they are fiddly to install and service and much more costly. I would not recommend a surge brake (common with boat trailers because of corrosion problems with electric brakes and with rental trailers because they don't require a brake controller) because the braking performance is poor.
Most people who put on electric-over-hydraulic disc brakes seem to be happiest with the Carlisle actuator and the Dexter brakes.
Depends what you have now. If you have a good electric brake controller, you can use it with either electric brakes or the Carlisle actuator.
02-28-2012, 12:27 PM
Long Beach
Thank you for the replys, especially Jammer for the time spent. That is all I need for reassurance to make the right choice! New axle will be on order with electric brakes, as soon as I can procure the wheels I want to replace the split rims. The wheel selection will finalize measurements for axle. Hopefully to avoid surprises tying it all together. This thread definitely helps.
Can,t wait to remove that old stuff off the tounge!
02-28-2012, 06:47 PM
mapleton
, Utah
Just curious- are you going to stay old school with the leaf spring set up or go more modern with a dexter, etc. Straight or dropped axle?
the originals are easily rebuildable with modern electric brake backing plates and parts if you are so inclined.
Enquiring minds want to know!
Tim
02-28-2012, 11:40 PM
Long Beach
Tim
Eowww! My brain hurts now. haha. Is there a better alternative... I was going with the "When in doubt, replace the whole thing." theme. I have a standing order with a local trailer shop for a Dexter axle replacement, same dropped axle measurement, electric brakes, six lugs. I had planned to go to Inland RV for my first visit, and for various other reasons. Perhaps I should have just gone there for advice. It may not be to late, and could cancel the order due to the shop waiting for my wheel selection before actually placing the order.
I once replaced Haddco drums on another trailer, and ended up having a new axle fabricated with modern parts. This time around I thought to just order a new axle with the Dexter brake assembly.
The springs would eventually get replaced, but I want it rolling on a new axle before new leaf springs are installed. Trailer is up on stands at the moment, and will need to be rolling to get it from point A to B again.
I am told that there are not any stock replacements these days for the exact size needed, and will have to relocate the mounting hardware. For that I want someone with more welding experience than myself.
Should I consider a torsion axle instead?
02-29-2012, 05:12 PM
mapleton
, Utah
Some have changed out to the modern style torsion axles for the advantage gain of independent suspension and a perceived ride improvement, others have simply refurbished the existing springs- again a fairly simple and inexpensive option. I very much doubt you will find anyone here who would recommend changing out your original long spring set for the much shorter currently available sets. this change would concentrate stress on a shorter portion of an already understrength frame.
Go with a torsion axle or rebuild your original, you decide which is best for your uses.
Tim
03-15-2012, 04:53 PM
1957 22' Flying Cloud
Bozeman
, MT
Did you every figure out what the brake controller or whatever is in the first picture is. Just brought home a 1957 26' with the same contraption on it. I don't think this unit every had any (12 volt) system installed. thanks terry
03-15-2012, 05:26 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
I never had the opportunity to actually see the components, but my aunt described the system to me shortly after I purchased my Overlander in 1995. The couple who had purchased my Overlander in 1964 had been Airstreaming since the 1950s, and they traded in their 195? Airstream on the Overlander, and it had hydralic brakes that tapped into the tow vehicles brakes (The Overlander had 4-wheel electric drum brakes standard as had all Airstreams for several years). There was a fixture mounted next to the Reese hitch on the rear bumper of the tow vehicle where a flexible rubber brake hose connected the Airstream and their 1955 Mercury Monterey - - and it often meant that the brakes had to be bled on both the Mercury and trailer if everything wasn't done precisely according to directions.
I can't say whether the hydraulic brakes were standard, an option, or special order, but I do know that they have been present on a number of Vintage Airstreams pre-dating 1965(?). I don't know when the electric drum brakes becam standard but I believe that it was probably 1960 or before). My 1964 Overlander was a special order for its original owners (who were long-time friends of my family) and it was equipped with one axle having electric brakes and the second axle having hydraulic brakes. The purpose behind this configuration was that they didn't want to make any changes to their 1955 Mercury so that they could tow the Overlander with the Monterey. They had a new 1965 Mercury Monterey on order, but they knew that they would continue to use both tow vehicles.
I believe what is on the front hitch in the first photo is the hydraulic breakaway device. The lever that is partially out of the photo at the top is raised until it "latches over the bi-level knot on the base of the device --- then a wire cable would attach the lever to the rear of the tow vehicle (just as on our current electric breakaway devices) --- in the event of a breakaway --- the lever is pulled down and the eye-bolt presses the plunger in to trigger the hydraulic brakes on the trailer. I believe that the plumbing to attach the tow vehicle's brake system to the trailer's brake system is missing, and even if it were there, it wouldn't be functional with the plumbing on a modern tow vehicle.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
03-15-2012, 06:16 PM
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville
, Wisconsin
We have a 58 World Traveler...what that is on the tongue is part of the break system...it actually connected to the cars hydraulic brakes! Yikes. When we restore ours, Im planning on leaving the appearance, but replacing the hydraulics with electric brakes.
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
03-15-2012, 11:41 PM
Long Beach
Thanks Kevin (overlander64) for the explanation. You did a great job describing it, much better than I could have done. I was just going to say "emergency surge brakes".
Just got the new tires so that I can tow it safely. I decided to go with the torsion axles with electric brakes due to everyone's comments. Thank you. The axle has been mounted back into position to take to Inland RV for the install. I did not want to trust my own welding skills on a chassis component.
The front surge brakes have been unbolted and long gone with recycle trash! I couldn't get it off fast enough, and feel that it was a weight lifted off the tongue.
My next decision is the size drum? 10" or 12". I think 10" should be fine, but it has 12" drums currently. Would 12" with a modern axle be over kill?
03-16-2012, 05:11 AM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
Id venture to think that the 10" would be sufficient...as your trailer is rather short...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
03-16-2012, 04:26 PM
Bozeman
, MT
Thanks, for the info. I figured it was some type of hydralic brake, since this 1957 never had any 12 Volt system. It will be removed soon, but previous owner didn't have a clue. Tried to insert picture but my pictures usually don't work. Terry
03-19-2012, 11:01 PM
(-1 Rivet_
1965 20' Globetrotter
Jackson
hey tlcbuilder, is this the tongue of your '58 18' "Footer"?
I am looking to pick one up this weekend and have some questions,
can I ask you some things?
Ball size?
I have 7-14.5 tires, do you or did you?
Have any info on bearings?
Sorry, not to highjack this thread, ( see other thread, 1958 18' wheel bearings)
but I'm in a pinch and cannot find any info,
Cuyeda, do you have any info for original axle wheel bearings?
Thx in advance
TIMK
03-19-2012, 11:28 PM
1964 19' Globetrotter
South Kingstown
, Rhode Island
curious about the switch to a torsion axle from the leaf springs: aren't you concentrating forces (the upward force from hitting a bump) on on point of the axle with the torsion Dexter, rather than the way the leaf spring axle would spread the forces out over a wider area of the frame, through the 4 leaf spring mounting points?
One thing I had heard about the hydraulic systems is that if there was a leak, you lost both the brakes in the tow vehicle and the trailer. Before 1967-68, most cars had a single circuit brake system so with no redundancy. I'd go with a leaf spring set up but with electric brakes.
Wherever you go, there you are
03-20-2012, 10:52 PM
(-1 Rivet_
Jackson
cuyeda,
Bear with me as I am new to this trailer, but have some questions ( and will probably answer them as I read other posts).
What is the bolt pattern/size of hub on the axel? (7x15x5.5OC, 12" drum?)
What size wheel/tire are you using? Offset?
If it had 7x14.5 split rims, did you go with 15"?
BTW, that big piece of metal with be the first thing to go on my 1958 18' California I'm picking up this weekend. Although it may become yard art...LOL
Thanks in advance,
TIMK
Thanks in advance!
TAC CA-77
03-21-2012, 11:39 AM
Long Beach
Originally Posted by REDSLED88
cuyeda,
Thanks in advance,
TIMK
Can you post any photos of your interior for comparison when you get a chance.
Not an expert, but will answer what I can.
Original drum size: 12", and will probably go with 10" (undetermined).
Original tire size: 7.00x15
Costco sells trailer tires now: ST 225 75R 15 Load range D
Original split rims: 15", 6 lugs
Installed bolt pattern: 6 lugs, vintage Chevy truck wheels, 0 offset.
1947 Curtis Wright
1958 Traveler 18'
03-21-2012, 12:18 PM
(-1 Rivet_
Jackson
Excellent, thx
Great info, just wanted to confirm wheel size, wanted to make sure the ST225/75D15 would fit inside the wheel well of my 1958 18' California.
Here are some pics, as is, but may help. If you do a search for vintage airstream photo archives you can find a bunch of info/pics of each year/style.
I would want to stay with 12" drum if possible, and I think some research on axle replacement should lead you to sollutions. I believe a Dexter axle, or Axis would work. They offer a straight or 4" drop, the straight will give you more body height, and the drop will look original. may be able to get say 225/70 or 225/65 tires to lower the height if you go with straight axle. I would not go with a dura-torque torsion axle, since the '58 has leaf springs it would be easy to just stay with leaf springs and replace the axle
Again, do a search for vintage airstream, conversion parts list, and axle options and you should get some good pics/info.
I would provide the link, but I am not sure if Airforums will monitor the post.
Thanks in Advance,
TIMK
Thanks in advance!
TAC CA-77
03-25-2012, 09:36 PM
(-1 Rivet_
Jackson
Twin beds in Front
My 1958 18' Traveler, made in Ca., #4201 has twin bunks in the front.
Unsure if this was original, or made after production.
Floor is completely rotted, all interior cabinets are completely anihilated, plus the axle has to be replaced. This picture has identical axle as the one in my '58. However my wheel wells are tear drop shape.
BTW, I will be going with a straight Dexter axel and leaf spring combo, electric brakes, stock steel wheels with baby moons.
Anywho, cuyeda add some more pics of the work.... we like the pics!
TIMK
Thanks in advance!
TAC CA-77
