Old 05-22-2012, 03:45 PM   #1
THEMACS3's Avatar
Williamsburg , Virginia
No brakes when battery is hooked up
Ok so here's the issue. When I connect the battery in my '73 over lander, I loose my brakes. Any iras?
THEMACS3 is offline   Reply With Quote
Old 05-22-2012, 04:15 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The only connect to the brakes from the trailer battery is through the emergency disconnect switch. If the pin is pulled from that switch the brakes should be LOCKED.
Are you saying that connection the trailer battery cause you to lose the braking function from the TV controller when hooked up?
I can't see a wiring error that would account for this.
2004 Excursion 4x4
Old 05-22-2012, 06:33 PM   #3
THEMACS3's Avatar
That's exactly what's happening. Once I connect the battery, the tv controller doesn't recognize that the trailer is connected and therefore no brakes.
Old 05-22-2012, 06:36 PM   #4
THEMACS3's Avatar
I also trie disconnecting the emergency disconnect system and had the same results. New disconnect system didn't help the issue either. Could use any suggestions you might have
Old 05-22-2012, 06:37 PM   #5
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Is it just the brakes?
Eric H is offline   Reply With Quote
Old 05-22-2012, 06:46 PM   #6
THEMACS3's Avatar
Yes just the brakes
Old 05-22-2012, 06:58 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Check your grounds.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-22-2012, 08:25 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would check the UCord wiring out completely as well as the breakaway switch wiring along with the wiring at the brake drums.
The only way that connecting the house battery would and should affect the brake operation is when the pin in the breakaway switch is pulled. When this happens the trailer brakes should be energized.
TG Twinkie is online now   Reply With Quote
Old 05-22-2012, 08:58 PM   #9
HowieE's Avatar
Images: 12
Did this combination of TV and trailer ever work together?
Some of the newer controllers have a constant small current from the controller to the trailer to show proof of connection. While I can say for sure what might happen if the trailer battery were to back feed that circuit. I would suggest that you prove out both the TV and Trailer connections. Use this diagram as a guide.
Electrical Tips
Checking the TV is straight forward by just using a volt meter and selection the different functions. If you insert a #12 wire in the terminal located at 1 o clock on the trailer cord you should be able to test the directional lights at 3 and 9 o clock and the parking lights at 11 O clock put touching the test wire at these locations. If these test OK touch the wire to 4 o clock. That should be the brakes and someone standing next to the trailer should hear them click on and off.
I say a #12 wire because when you test the brake circuit you will be drawing 3.5 amps per brake and a smaller wire will melt in you hands.
Let us know the results.
2004 Excursion 4x4
Old 05-23-2012, 02:35 AM   #10
THEMACS3's Avatar
I did test the tv controller and harness out, they are working properly. What is the UCord?
Old 05-23-2012, 05:22 AM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Has the trailer and tow vehicle always had this problem?
Has the trailer always done this or is it a new development?
Do the trailer brakes work with any other tow vehicle?
Old 05-23-2012, 05:50 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The UCord is the same as the harness that connects the trailer to the TV.
Do all of the lights work the way they should on the trailer exterior? Tail lights, turn signals etc.
Old 05-23-2012, 06:27 AM   #13
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Is it possible the the trailer battery is reversed ... or just the braking circuit ... polarity backwards? I've never thought this through, but it seems to me that other circuits, such as the lights, etc. would not care positvie ground vs. negative ground - they likely would work either way, and likely would not interact with the t.v. battery in the same way as the braking circuit. (Vent fans might run backwards, though, I suppose.) This is an odd one.
AirsDream is offline   Reply With Quote
Old 05-23-2012, 07:01 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the trailer has a converter, you would know if the battery were reversed. The TV wouldn't like it either.
Have you checked to see if one or more of the brake coils is shorted to ground?
