Old 06-29-2014, 09:01 PM   #1
Boerne , Texas
No brakes on two of six wheels
The triple axle 34' had 2 wheels on the same side that didn't work. I removed the drum and found that one wire on each wheel had broken. Solders them up and they work again. It wouldn't have been so bad but both were on the same side and caused a sideways pull when the brakes were on.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 06-29-2014, 09:43 PM   #2
Good reason to pull the drums so that a visual inspection can be made of the brakes, once a year or every 10,000 miles, which ever is first.
Old 06-29-2014, 11:08 PM   #3
1974 Argosy 20
Kooskia , Idaho
That is a real common problem, broken wires to the wheel magnets. I once found 3 of my 4 brakes were not working, due to wires which hand corroded. I now have a test gadget which I built that plugs into the cord to the tow vehicle and measures ampere flow to the magnets. Each takes 2.5 to 3 amps, so on my single axle rigs I expect to see 5 to 6 amps, double axel 10 to 12 amps and for your tri axle, 15 to 18 amps. Anything less means a magnet is not working somewhere.
Old 06-30-2014, 06:44 AM   #4
1981 31' Excella II
New Market , Alabama
You might want to free up the adjusters as well so you can adjust them when you get it back together.
Perry
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
