Old 08-06-2010, 11:43 PM   #1
Edson , Alberta
Question No brakes, but everything else works... what's wrong?
Hi there,
I just got my first Airstream last month (a 1974 31' footer) and I can't get the brakes to work. I just got a brand new Tekonsha brake controller put in my truck and it always says " n.c " (not connected) when connected to the trailer. I tested the controller and truck with my parent's 5th wheel, and it works fine. So what's wrong? All my turn signals and brakes lights work fine on the airstream... and the guy I bought the trailer from said the brakes worked fine for him. Is there something I'm missing here?
Thanks!
groshko is offline   Reply With Quote
Old 08-07-2010, 06:57 AM   #2
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet Beware of different wiring on look alike connectors
Originally Posted by groshko View Post
Hi there,
Thanks!
Welcome to the forums.
Since the new Tekonsha works fine on your parents 5th wheel, probably a 7 pin setup, it's not the truck. Even though the connector may look the same some airstreams had a 6 pin setup (same plug just less connectors used in it) meaning you have to match the wiring correctly to make the brakes system work on the trailer. I'd start with checking the wiring diagram on the airstream to match up to the truck plug, or you have a break in the trailer brake wire system.
arcamedies is offline   Reply With Quote
Old 08-07-2010, 07:25 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a good battery in the trailer. Jack up one side of the trailer and while someone is spinning one of the wheels take a piece of #12 wire and jump the connections at 11 and 7 o clock, power and brakes wires, on the trailer plug. If the wheel stops the brake system on the trailer is working and the problem is in the TV. If the wheel does not stop the problem in in the trailer.
Post the results and we can go from there.
2004 Excursion 4x4
Old 08-07-2010, 07:53 AM   #4
richinny's Avatar
2011 34' Classic
when you test for voltage at the truck connector, do you have voltage there when you step on the brake?
Ricky
Old 08-07-2010, 08:28 AM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
On a tow vehicle with a jumper light, the brakes and the stop lights look the same. A 7 way tester is a quick way to verify the tow vehicle is wired right and working and it looks good in any tool tray. On my trailer, the previous owner did a Super Bowl party midnight install on a replacement 7 way trailer plug by eliminating the break away switch, and removing the fuse panel. Nothing was soldered. It was all twisted and taped. I took it all apart and rewired it all with a new break away switch.
After I assumed nothing was right on my systems, I made progress.
Gary
Old 08-07-2010, 05:51 PM   #6
Edson , Alberta
Yeah, I took apart the 7 way cable and the yellow wire wasn't making contact. Fixed it now and all is good.
Thanks!
brakes, electrical
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 09:16 PM
What Am I Doing Wrong? StingrayL82 Batteries, Univolts, Converters & Inverters 37 09-01-2009 05:29 PM
Look under here and tell me what's wrong connorsa Ribs, Skins & Rivets 6 07-13-2009 09:51 AM
What's wrong... rickandsandi Off Topic Forum 18 08-07-2007 05:59 PM
