Effective February 1, 2005, all Classic trailers built by Airstream, will be equipped with "Disc Brakes."
The brake system is made by Kodiak and the actuator is made by ActiBrake.
These are the same components we chose sometime back.
Looks like this confirms that electric brakes will be a thing of the past.
Retro fitting the older trailers will not only make the owner a "Real Happy Camper" it will greatly inrease the braking performance, as well as add value to the trailers.
Real good news...thanks for posting this info Andy!
I'm curious, why do I want disc brakes on my trailer.
I have never experianced brake fade, or any other problems I can pin point to being caused by the brakeing system. I have a small trailer and a large truck.
What is the advantage of disc brakes on a trailer. Is it just a fadeing thing?
There are many advantages to disc brakes over electric brakes.
For that matter there are many advantages to disc brakes over hydraulic brakes. If not, then why has the automotive industry changed to them?
Contrary to your thoughts, electric brakes are very famous for fade. Secondly, your large truck does not and cannot offer security if you had to make a panic stop. If you made a panic stop, and your trailer brakes faded, you can and usually will get into a sway condition that you really don't want to experience.
Additionally, disc brakes provide outstanding stopping performance and much smoother as well. Disc brakes also have one moving part versus six to twelve for electric brakes. Repair parts for the disc brakes are available at many auto parts stores. Not so for electric brakes.
Bottom line is the discs are much safer, better performing and considerably more reliable than electric brakes could ever be.
Please don't be mislead about the size of your truck. It does not offer any "magic" should you get into a sway. Many records prove that.
I agree. If it's good enough for the auto industry, it's gotta be just as good for the RV industry. Put it this way, it couldn't hurt...and that's not knocking electric drums...they've been out there for years, but improvements in technology and overall lower cost as time goes on, to me makes it a no brainer....not that I'd run out and change the Safari brakes, I wouldn't, but if I had a choice as I do on tow vehicles, I would always opt for discs.
Good example is on the Impala SS. The sister car the Caprice in some configs had the exact same engine (minus mechanical cooling fan), same trans, etc. The SS got 4 wheel discs, the Caprice got front discs and rear drums. It kind of tells me that GM figured folks driving an SS with the special tires and suspension would need to bring the car down from worp speed and that disc (as found on the police packages) provided better stopping. I have both versions of this car I mention (Caprice and Impala SS). The Impala stops on a dime and can give you a nickel change.....the Caprice can too, but after a while, the brakes on the Caprice tend to fade faster than that of the SS's all wheel disc setup.
Approximately how much would it cost to get the electric brakes on my dual axle 30' Classic switched to disc brakes?
John
Me thinks your first born.
The prices for the various kits are posted on our web site, in the parts section.
With Airstream now putting both the upgraded axles and the disc brakes on the 2005 Classics, this sounds to me like 2 significant improvements over prior year models...now that I just saw the prices for the disc brakes, however, I'll have to give some more thought about giving up my firstborn to get them.
I agree 100%. My 63 Overlander project will receive new axles with disc brakes. One trip over Wolf Creek Pass in Colorado quickly made me aware of the shortcomings of conventional electric drum brakes. Besides, the balancing issue is much improved with disc brakes over drum brakes.
The electical signal from the brake controller in the tow vehicle goes to a small hydraulic pump. From the pump, the system is hydraulic, just like a 1984 Chevy Cavalier.
