Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Prev Previous Post   Next Post Next
Old 06-23-2009, 09:21 AM   #1
Profile:  1964 26' Overlander
Kearney , Missouri
New Electric Brakes not working on 64 Overlander
I recently started rehabing my 64 Overlander and started with the drive train first. Replaced shocks then took it to the shop to have the axles inspected, they are in good working order. Had the electric brakes replaced as well as the running lights checked and new plug put on trailer in front hooked it all up to a new brake controller. Outside running lights work well ( I replaced the originals with new tear drop lights) and everything worked well for 1-2 weeks. Then the electric brakes quit working and the green light on the brake controller went out. The running lights continued to work. Went back to the shop where the brake controller was checked and was operating properly. The shop states there is a ground wire "loose" on the trailer that is preventing the electric brakes from working. Does anyone haver any idea where to check for this issue?
Thank you.
64Overlander is offline   Reply With Quote
Electronic Brakes Not Working So Well... paddler3d Brakes & Brake Controllers 20 05-23-2009 05:12 AM
Brakes on Passenger Side Not Working - Please Help Mookie Brakes & Brake Controllers 4 11-04-2007 06:45 PM
Help!! Disc brakes aren't working!! sequoiacoast Brakes & Brake Controllers 85 09-26-2007 10:55 AM
Electric Brakes - Are they working? bevman Brakes & Brake Controllers 12 08-25-2007 03:47 PM
Brakes working correctly? Dbraw Electrical - Systems, Generators, Batteries & Solar 8 02-27-2007 08:16 AM
