Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 12-26-2005, 04:10 PM   #15
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
LRPorter
What kind of tires is that dealer selling you?
Goodyear Marathon is best as that has been the factories choice for many years.
If he is selling something else, I would pull the trailer out like a rocket, especially since he 'obviously" does not know how to check shocks.
Rule of thumb is easy. When you put new tires in the trailer, replace the shocks as well.
Keep in mind that your trailer uses horizontal shocks, and they are only available from an Airstream dealer.
Can that dealer balance the running gear for you, as it should be done?
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-13-2006, 11:04 PM   #16
axleman
Commercial Vendor
Profile:  Currently Looking...
Somewhere , Indiana
Well said!
Originally Posted by uwe
I did the axles on my 1971 Tradewind 2 years ago. I bought complete Henschen axles from Andy. Henschen shipped the wrong axles, so i had to do the job twice,and was exposed to the brake drums twice as well, since I had to transfer them from one set of axles to the other.
Better balanced? Not even close....
Took the trailer to Andys InlandRV shortly thereafter for a balance job, and it took an ungodly amount of weight to make things right.
There might be a slight improvement, but it's still far from perfect.
Uwe,
It has been my experience that "Disc Brake Rotors" are fairly true, while drums vary quite a bit.
Well said,
Henry
axleman is offline   Reply With Quote
Old 09-23-2006, 12:04 PM   #17
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
A mere 9 months later
I finally got around to replacing my wheel drums, and I must say that these new ones rotate much truer than the original ones did. Although the real test will not be until the first part of October when we head to Disneyworld, I sense that all my vibration issues have been resolved.
I feel much better now.
Tom
p.s. FWIW, the new drums came attached to new axles.
Old 09-23-2006, 09:56 PM   #18
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
Andy is right about the balance of running gear ,the reason its so important on the torsion axles is because the axle tube is in direct contact with the frame ,even welded to it on early bambis sometimes. the torsion arm is short
so all vibration from imbalance ,drums ,tires etc is transmitted right to the trailer ,of course some is absorb by the rubber rods in the axles and
the shocks .something needs to control that shaking .the leaf spring axles
on the other hand do not have the axle anywhere near the frame to make contact with it ,and with good shocks and good tire balance ,no issues to
speak of .I will say that a good quality tire ,radial or otherwise will work fine.
Scott
scottanlily is offline   Reply With Quote
Old 09-23-2006, 10:53 PM   #19
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
38 Year old brake drums.
Hi, You did the right thing replaceing the 38 year old brake drums. I don't remember brake drums being so bad 38 years ago, But with normal wear, loose plates, rust, and the machineing of warped, out of round, and with hot spots being removed its going to change the balance of the original casting.
In the old days cast iron parts were made in America and set aside to cure; To take final shape before final machineing was done. Now some of these parts are cast, machined, and shipped to America from God knows where?
Also in the old days we had a few ways to spin balance wheels on the vehicle. Therefore balance all spinning parts. But it was too time consuming. So here we are in modern America wanting everything yesterday.
Bottom line your drums were bad from age, wear, and tear, not poor workmanship done 38 years ago!
ROBERTSUNRUS is online now   Reply With Quote
Old 09-23-2006, 11:30 PM   #20
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I have a hard time seeing the need to balance the wheels with the drum.
I never heard of this being done on cars-trucks.
It has been working on millions of cars for years without doing this.
Anybody backup this procedure with doc's from the manufacturer
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-24-2006, 12:28 PM   #21
Commercial Vendor
This subject was tossed around on this site a long time ago.
All automobile and light truck hub and drums are balanced when manufactured.
That "is not" the case with "any" travel trailer hub and drum, be it an assembly or unicast, ever made as of today.
Part of the theory seems to be that since you don't ride in the trailer, then "who cares" if it shakes. Also, there is a cost to balance them, it seems to most manufacurers, to be high enough to price themselves out of market.
Accordingly, you "must" balance the tire and wheel "and" the hub and drum, as an assembly.
It's your investment, therefore your choice. The vast majority of Airstream owners, chose to abide by the proper "PM" principles. Some of them, unfortunately, learned that lesson, the hard way.
From 1973 and back, the primary cause of rear end separation, as well as many other problems, was "lack" of proper running gear balance. From 1973 up to and including today, lack of proper running gear balance is an absolute guarantee of crazy and usually expensive repairs, that could have, so very easily, been avoided.
Therefore, in time, the message became loud and clear. Balance the running gear, or else.
Inlandrv.com
800-8777311
Old 09-24-2006, 04:07 PM   #22
TomW
TomW's Avatar
Normal , Alabama
Images: 77
So why does Airstream Inc. not do it?
Originally Posted by Inland Andy
...All automobile and light truck hub and drums are balanced when manufactured.
That "is not" the case with "any" travel trailer hub and drum, be it an assembly or unicast, ever made as of today....Accordingly, you "must" balance the tire and wheel "and" the hub and drum, as an assembly.
It's your investment, therefore your choice. The vast majority of Airstream owners...
Andy,
Since balancing drums is apparently commonplace, why does Airstream Inc. choose not to have their axle vendor do it on new assemblies? Obviously it will add dollars to the purchase price, but what new purchaser would notice? It appears to me to be a good selling point.
Tom
Old 09-24-2006, 04:22 PM   #23
Commercial Vendor
Originally Posted by TomW
Andy,
Tom
Henschen and Dexter do not balance drums.
Inlandrv.com
800-8777311
Old 09-24-2006, 06:29 PM   #24
TomW
TomW's Avatar
Normal , Alabama
Images: 77
I would not know.
But if they do not, other companies do. Whoever makes the drums for the two companies could ship the drums to another party for balancing.
So [a modifcation on the question] still remains - Why does Airstream Inc. choose not to have their axle assemblies balanced before incorporation into a new Airstream?
Tom
Old 09-24-2006, 06:47 PM   #25
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Tom
I do not know for sure, and I would guess that the axle manufactures make ther own drums. And I would also guess that no trailer axle company balances their braking assemblies. For if you look at the end user, utillity trailers, HD equipment used at slower speeds, then it might be assumed the market dictates that there isn't much need for balanced braking assemblies. Just a guess on my part.
In the automotive arena, most automanufactures make there own running gear or contract out for it in a balanced condition. And most automotive applications use disc braking or smaller drums in the rear. The smaller the drum the less concern for rotating mass. And rotors are far easier to keep balanced.
>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-24-2006, 08:25 PM   #26
markdoane
Profile:  , Minnesota
Images: 59
I'm sure with all the Millions of dollars that Airstream has spent on product design and engineering, they have decided that it is not necessary to balance the drums.
That's my opinion and I'm sticking with it.
Non-contributing deadbeat.
Old 09-24-2006, 09:07 PM   #27
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Andy, I'm missing something here. What happened in 1973 that changed things? I have a 1973 so I'm curious. Are you saying that all trailers built after 1973 need to have the drum assembly balanced with the wheels/tires? Help a rookie axle guy out here, how is that done? I rememeber the "old days" when tires/wheels/etc could all be spin balanced while mounted on the car/truck. This can only be done by a few shops these days?
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Old 09-25-2006, 08:13 AM   #28
axleman
Commercial Vendor
Somewhere , Indiana
Hmmmmm!
Don,
I would be curious of the cost to do the balance job vs. the necessity. In other words you may be right - it's not worth the cost. Uwe has tried it both ways and didn't seem to notice a difference.
Regards,
Henry
gear ratios RVNUTTY Towing, Tow Vehicles & Hitches 11 09-04-2004 04:38 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 04:14 PM
Add Running Gear Links Here Action Link Archive 2 09-13-2002 09:01 PM
Correct color of bumper and tongue gmc70 Clearcoat, Exterior Paint & Trim 2 06-24-2002 07:19 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 09:00 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum -
