Old 09-23-2017, 05:44 PM   #1
1982 27' Excella
Huntsville , Texas
New Dexter Break Wiring
I purchased replacement Dexter drum brakes, baking plates, pads etc. It all came assembled. The wires coming out of the backing plate are the same color - green. The trailer wiring going to the brakes are different colors. Question: Does it matter how the wires are connected? Since the breaks are self adjusting is anything necessary when I first start diving the trailer?
GMarugg is offline   Reply With Quote
Old 09-23-2017, 06:09 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
It doesn't matter how you connect them. The magnets will work either way.
Unlike the old self-adjusting car brakes, the self-adjusting trailer brakes adjust when going forward. Several stops will have them adjusted, but they will not develop full stopping power until the shoes bed in to the drums. Be aware that you may have limited stopping power for a while after installing.
Al
Old 09-23-2017, 07:39 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
One wire from each break goes to the ground wire. The other wire from each drum goes to the brake wire on the 7 pin *and* to the breakaway switch. Pick either wire, it does not matter which one goes where.
Old 09-23-2017, 08:31 PM   #4
1982 27' Excella
Huntsville , Texas
Dexter Breakes
Thanks for the help. I was concerned that one direction would attract and the other would repel
Break-in period for new Dexter 12" assemblies wulfraat Brakes & Brake Controllers 7 03-24-2017 06:47 PM
Break away wiring harcon 1970 - 1973 Overlander 3 11-10-2016 08:55 AM
new break system for a 1971 31' Land Yacht project Oddman General Repair Forum 1 08-21-2013 09:35 AM
1972 Safari break wiring slk Brakes & Brake Controllers 2 06-09-2009 09:29 AM
