Old 11-09-2011, 03:26 PM   #1
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
New Brakes-Wiring?
The etrailer diagram says to ground one of the brake wires to the chassis. Is it OK to use one of the backing plate bolts? Or do I need to run it to the frame and bolt it there?
FC7039 is offline   Reply With Quote
Old 11-09-2011, 03:33 PM   #2
Flysoncloud's Avatar
1953 21' Flying Cloud
Wentzville , Missouri
Any point that is in contact with the fame will ground the brakes. If there is any kind of rubber mounts between the axle and the frame it will not ground. Moving parts even if they are metal do not make for good clean grounds so while it will work on your backing plate it is not the best choice.
I have read about the evils of drinking beer so I quit reading.
Flysoncloud is offline   Reply With Quote
Old 11-09-2011, 03:36 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I'd go to the frame, or better yet, go all the way back to the umbilical cord. The last thing you want is corrosion or paint interfering with the operation of your brakes. Assuming that your frame or axel mounting points are either painted or rusted, either one can prevent making a good connection and will prevent electricity flowing.
Chris
Old 11-09-2011, 03:41 PM   #4
r carl's Avatar
Lin , Ne
Bolt to the frame, you want your brakes to have a good ground.
Old 11-09-2011, 04:29 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Mount to the frame and make sure you allow enough wire for a Service Loop between the backer plate and the frame mounting. If your trailer has springs make sure the wires will clear all movement while on the road and allow for the trailer to be jacked up. If you have questions i would ty wrap the wires to the springs and make the service loop at the end of the spring where there will be the last movement.
2004 Excursion 4x4
Old 11-09-2011, 06:10 PM   #6
FC7039's Avatar
Allen , Texas
Thanks all.
Old 11-09-2011, 07:29 PM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The trailer manufacturers recommend using at least 12 gauge wire all the way back to the umbilical cord. I branched mine and used 10 gauge for the main run back to where it branches to the wheels.
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 15 05-04-2018 07:55 PM
Music Centre wiring? Dastardly 1970-79 Tradewind 2 08-22-2011 04:43 AM
Brake Controller Wiring Harness wlanford Brakes & Brake Controllers 3 08-01-2011 12:14 PM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
