Old 06-27-2007, 10:36 AM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have to back off on the adjuster that many clicks to get free wheeling you may have gone to a point beyond the through of the magnet arm and thus Poor Brakes if brakes at all.
Since the rear shoes are burnt and need replaceing you will find it is cheaper to buy complete new backer plate assemblies on line then shoes from a local shop.
2004 Excursion 4x4
Old 06-27-2007, 10:58 AM   #16
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
You know, Uwe isn't that far off. 10" disk brake conversions for a one axle trailer aren't that much, especially if you'd have to do it anyway secondary to cheap brakes that you have now. Stick a surge brake hydralic actater on there (a 14" trailer won't need electric brakes like our trailer do - if it doesn't have one already), and cost should be quite minimal.
Just a thought.
Marc
Old 06-27-2007, 11:00 AM   #17
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
No - the wheel has always spun freely. you could hear that the brakes were rubbing a little at first and that stopped after the first backing off I did. But apparently that was not enough.
Yes - new setup is going to be in the works. I can do that myself easily so why not.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-27-2007, 11:01 AM   #18
1975 Argosy 26
1963 24' Tradewind
oops, you replied just before me... see above re: disks
Marc
Old 06-27-2007, 12:49 PM   #19
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Hey - thats a good idea. I have to look into this. Thanks for the suggestion!!
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
water heater bypass tomb 1984 - 1989 Sovereign 1 11-22-2002 01:04 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
