Old 11-02-2006, 06:46 AM   #1
kaffe_1477's Avatar
1963 16' Bambi
Metairie , Louisiana
Cool New brakes for a '63 Bambi....
So, without having any experience at all with breaks, I proceeded to explore the breaking system on my "63 Bambi. I noticed that an owner at some point had cut the wires to the breaks, therefore rendering them useless. My first thought that came to mind was that something must have gone wrong and they didn't want to spend the time and money to fix them and they probably had a larger vehicle with more than sufficient breaks to stop both the Bambi and the TV. My only option was to dive in and tear it down. (keep with me, I do have a question coming up.) After about a hundred mosquito bites I managed to get the curb side wheel and the drum off to expose the break assembly. My assumption is, that it is the original...but than again, it is a 43 year old trailer, Who knows what has been done to it. After the drum was removed I exposed the problem. The hardware that held the mag in place had the head rubbed clean off by the drum and the mag had a smooth bevel due to it hanging loosely and making contact with the drum. (I will add pictures soon...I was amazed that the trailer hadn't experienced a catastrophic failure.) Now to the question.
If I use a 10" x 2 1/4" backing plate assembly from Dexter, will it work with the current axle. Or in other words, do they have a standardized bolt hole pattern? and will the old drum...which appears to be in good shape just needs to be turned...work with the Dexter parts.
Another question... How long has Dexter been around? The axle that is on it very well could be a Dexter axle. the person I got the trailer from spent a lot of money getting some work done to it 10 years ago but has past away.
last question... I am running new 12ga. wire for the breaks. since they operate on DC, can I run them in series or do they have to be run in parallel?
I hope someone can help...
kaffe_1477 is offline   Reply With Quote
Old 11-02-2006, 06:54 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bolt pattern is standard
dexter has been around for a long time, your axles are probably henschens. (they use dexter parts)
wire the brakes in parallel. 12 ga is fine.
john
you call them ferrets, i call them weasels.
Old 11-02-2006, 08:24 AM   #3
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
63 Bambi brakes
Howdy kaffe, we have a 1963 Bambi that I spent the last year restoring. I am including some pictures to help you answer your questions. The first picture is the inside of a stock brake system. The second photo is of an oringinal henschen axel. The third picture is of a new Dexter. If you look at the section where the movable arm of the axle attaches to the cross axle member you will be able to tell the difference. The henschen is squareish where the Dexter has a more rounded shape. I hope this helps. I also have many pictures of the restoration process. So If you have additional questions, just ask.
Don
ID:	27928   Click image for larger version
Name:	7-8-2006 3-38-40 PM_0024.jpg
Name:	Axle bracker and axle.jpg
NorCal Bambi is offline   Reply With Quote
Old 11-02-2006, 10:29 AM   #4
kaffe_1477's Avatar
1963 16' Bambi
Thumbs up
I guess everything on my Bambi is stock then. I will go with the Dexter brakes then in the near future i will be getting a new axle.
Looking at the Pics...I don't see the shock that was in the stock setup. I know Dexter doesn't require a shock, but I cannot help but think that there was a reason that a/s put one on it. Also, when ordering a new axle what offset would you sugget?
Old 04-29-2007, 03:27 PM   #5
Goldtimer's Avatar
1963 16' Bambi
Decatur , Georgia
When are brakes need for '63 Bambi?
In the first post in this thread, there's speculation the previous owner cut the brake controls because he had a heavy enough tow vehicle (TV) to stop both the trailer and the TV.
What weight vehicle is adequate for not needing the trailer brakes?
Goldtimer is offline   Reply With Quote
Old 04-29-2007, 03:50 PM   #6
Images: 59
It's as much a legal requirement as a practical problem. Most states have a 3000lb weight limit before brakes are required. Some are less.
markdoane is online now   Reply With Quote
Old 04-29-2007, 03:59 PM   #7
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
That is determined by each state's law, which varies among the states. Look here for the specifics of your state law:
http://www.towingworld.com/articles/TowingLaws.htm
The chart shows Georgia requires brakes on trailers that weight 1,500 pounds or more, so your Bambi should have its electric brakes operational. A quick way to get the brakes working is to buy and install a "loaded blacking plate" that fits each side of your Bambi's axle. Do a search for "Bambi brakes" or similar terms on this web site for data on how others fixed their Bambi brakes. Good luck!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 04-29-2007, 06:30 PM   #8
Goldtimer's Avatar
1963 16' Bambi
Decatur , Georgia
Thanks, guys
That is most helpful info.
Looks like we'll have to get the brakes working, even though the 1800 lb. Bambi (believe I read that's all they weighed in '63) will be pulled by a 2500 construction pickup.
Old 10-15-2009, 07:40 AM   #9
kaffe_1477's Avatar
1963 16' Bambi
Wow, i realize this was an older thread that I must have forgotten about. Anyway, thanks for all the info. NorCal, I believe I visited your Thread after you posted to enjoy your project and quickly fixed the breaking situation shortly thereafter. As it turns our we have a Trucking supplyer close by that I was able to find the backing plates for i think around $45 each. Seamed like a great deal. Now I am fighting for the time to do a floor replacment and check my frame for needed repairs. With the cooler weather coming here in New orleans I am hoping to get to that.
Again, thanks you all for your help and I hope that this is good info for others.
BTW...I agree, I would never suggest towing any thing without breaks...but I can never tell what other people are thinking...only guess.
"This is grain, which any fool can eat, but for which the Lord intended a more divine means of consumption... Beer!"-Robin Hood, Prince of Thieves, Friar Tuck
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
