Old 04-02-2010, 04:18 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I gave away my shoe arcing machine (Ammco) in 1986. While you might think you have to scuff the shoes and drums when you do a brake job (it's a good idea), you don't have to. If you think about it, there's no little guy running around inside the drum scuffing it between brake applications to make the surface rough enough to stop your trailer. The drum and shoes should be cleaned before reassembly, the old dust can act as a lubricant, keeping the shoes and magnet from generating enough friction to stop the trailer. You should make several easy stops with new brakes no matter if it's your tow vehicle or your trailer, this will help seat the shoes, as well as cure the epoxy between the friction material and mounting table. They should be properly adjusted before leaving the shop where they were installed.
Old 04-08-2010, 12:21 AM   #16
JFScheck's Avatar
Rockville , Maryland
Images: 33
Sooooo Glad to have Disc Brakes - just dumb luck but still happy I got them...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-08-2010, 05:19 AM   #17
Well Preserved
1993 21' Sovereign
I've always said I'd rather be lucky than good.
Old 04-08-2010, 09:02 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
I'm glad you're happy.
Hi, I have stated this before and I will say it again; I would rather have drum brakes that always work than the better stopping disk brakes that sometimes work. Hopefully you won't have the problems others have had. Mostly actuator problems, but too many other problems to list. I'm sure if you search, you will read what I have read.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-08-2010, 10:14 PM   #19
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Exclamation New Brake Shoe Problem
Adjustment is the key. Ammco makes a tool so you can measure the diameter of the drum, and the other side of the tool gives the correct adjustment of the brake shoes BEFORE you re-install the drum. A brake specialist will have one of these in his toolbox to save time. Arcing brake shoes has disappeared as a practice on brake work because of the asbestos hazard involved. Shoe effectiveness will improve with miles as someone stated, and you shouldn't burn in new shoes. Sounds like the tech involved is not an ASE Certified Tech on brakes, or he would know better.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 04-12-2010, 10:17 AM   #20
JFScheck's Avatar
Images: 33
Originally Posted by ROBERTSUNRUS View Post
I would rather have drum brakes that always work than the better stopping disk brakes that sometimes work. Mostly actuator problems, but too many other problems to list. I'm sure if you search, you will read what I have read.
Yea - you know darn well I read ALL those threads to get up to speed...
I can comfortably stop the trailer with the TV alone (I have some MONSTER brakes on that bad boy) - let's hope I don't need too but comforting if necessary...
After much study out on the web/dealers/users it appears to myself and many others (as posted here too) that a certain brake actuator company had some bad units out in the field - lost a bit of money replacing fried electronics (that most think were caused by improper installs) and just closed up shop - waiting for them to reopen under another brand name (they are still in existence making "electronics modules" for the other "brake actuator" guy in town).
They also appear to have some issues with their first units - but those bugs were worked out long ago...
Unfortunately - in this day of the Internet - its hard to hide from your history...
**I Love U.S.A.**
Old 04-12-2010, 12:01 PM   #21
HowieE's Avatar
Princeton , New Jersey
Images: 12
Disc brakes have many advantages. They are great for high speed frequent stopping where heat is a problem. Neither of these conditions are present while towing a trailer. Drum brakes have the capicity to lock the trailer wheels, An indication of more braking than can be used.
Given this I can't see any reason to run the risk associated with failing actuators associated with disc brakes.
As for the problems having been fixed just do a search for those members that are still looking for an answer as how to get their systems to work for more that a day or so.
2004 Excursion 4x4
Old 04-12-2010, 04:19 PM   #22
Salem , Oregon
Images: 18
Hi, after just taking a walk in the neighborhood, [looking at parked cars] I was re-aqainted with another reason that I don't like disk brakes; Extremely dirty, stained, and pitted wheels. You never got that with drum brakes.
My Lincoln has four disk brakes, stops well, clean rear wheels, and slightly dirty front wheels.
My wife's BMW has four huge disk brakes and it can put your head through the windshield just by looking at the brake pedal. [slight exageration] But it makes those nice silver wheels look like junk yard crap in about a week. [black dust]
2005 Safari 25-B
Old 04-13-2010, 09:23 AM   #23
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
I really don't want to lock them up, but my four 12" brakes have never locked my wheels on dry pavement. Gravel or wet pavement, yes.
Maybe I could, if I turned the gain up all the way on the controller? But I can't drive with it that way and it doesn't seem to matter anyway.
We have really great braking between the trailer's four drums and the big red truck's four discs. Besides, you're not supposed to use the brakes, it slows the roll and cuts your gas mileage.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 04-13-2010, 09:53 AM   #24
HowieE's Avatar
Images: 12
The statement about drum brakes having the capacity to lock the wheel was not a suggestion that one should set up their system to do that. It is just that a statement of capacity. The selling point for disc brakes is often their higher ability reduce brake fade do to heat build up from frequent or extreme use. These conditions do not exist during towing there for there is little reason to use disc brakes on a trailer especially when they have not yet designed a control system that has any level of dependability.
Yes if the control system is ever accepted as having a level of dependability then there might be a reason to install disc brakes in trailers. Currently I see no gain.
2004 Excursion 4x4
Old 04-13-2010, 10:51 AM   #25
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have the impression that brake lock up is more difficult to obtain with the electronic controllers because many of them pulse the brakes. With the old hydraulic controllers lock up seemed easier to achieve, not that you would want to.
The only disc brake setup I ever pulled was on a 36 ft 13000 lb cedar creek 5th wheel.
Apparently the hydraulic pump in these systems is powered from the trailer battery, while the info on "how hard to pump" comes from the TV brake controller.
When delivering new trailers we normally do not have the charge line on since a lot of unit will have lights on inside and we may not have keys to get in and turn them off.
Any way the trailer quickly drained the small battery I was using for the breakaway battery and I suddenly had no brakes.
No disaster as a result but it did take some head scratching to figure out the problem and turn the charge line on.
Just something to keep in mind. Dead trailer battery , possibly no brakes with disks
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-13-2010, 11:41 AM   #26
1980 31' Excella II
Drummond Island , Michigan
Drum brakes are reliable and do not have a lot of ancillary parts to fail. They do have to be adjusted properly unless you have the new self adjusting brakes Dexter released recently. I like discs because they work better in extreme braking situations and do not need adjustment but you have to pay attention to the pad wear condition because worn out pads will do in a disc brake rotor very quickly. If you have been boondocking and have run down your trailer battery you could also have a problem with brakes until the battery is recharged. There are pluses and minuses on both sides of this question but I lean towards reliabilty and simplicity.
Ahzmyrah is offline   Reply With Quote
brake controller problem blujaz65 Brakes & Brake Controllers 3 03-09-2010 09:09 AM
Brake problem Farmer Dan Brakes & Brake Controllers 2 09-24-2008 09:23 AM
Brake wiring problem in a 71 Lumatic Brakes & Brake Controllers 9 06-10-2008 09:52 PM
brake shoe retainer springs and pins.. safari25-05 Brakes & Brake Controllers 1 04-08-2007 05:17 PM
Brake Problem moveinon Brakes & Brake Controllers 3 04-26-2004 08:00 AM
