Old 01-24-2012, 09:39 AM   #15
1986 25' Sovereign
Plant City , Florida
Originally Posted by 68 TWind
They may just need time to "set in". When I installed new axles on my Trade Wind I was not happy with the brake performance. I check the adjustment twice. Full power with the brake controller just did not seem to provide much stopping power. But after about 200 miles of towing with a good number of stops I checked them again. Pulled the lever on the controller all the way over at about 25 MPH and wow, locked up all 4 wheels. May just need to give it some time before you get too deep in to solving a problem you may not really have to solve.
Great advice. I just hope I don't need to stop quickly during the first 200 miles. Lol
ck21084 is offline   Reply With Quote
Old 01-24-2012, 09:50 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by ck21084 View Post
The reading at each magnet is 3 amps.
I 'tink 'dat may be the problem....
Electromagnet Specifications
10 and 12 Inch Brake Drums Max Amps at 12-13 Volts
2 Brakes 7.5-8.2
4 Brakes 15.0-16.3
6 Brakes 22.6-24.5
7 inch Diameter Brake Drum Max Amps at 12-13 Volts
2 Brakes 6.3-6.8
4 Brakes 12.6-13.7
6 Brakes 19.0-20.6
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-24-2012, 10:27 AM   #17
Current electric brake adjusting screws have 8 notches.
The threads are 20 per inch.
Therefore, 8 clicks will move the adjuster 1/20 of an inch, 05 .050 of an inch.
Usually the brakes are adjusted by pull the wheel with one hand, so that it turns.
Then, turn the adjuster so that you cannot pull the wheel to make a circle, WITH ONE HAND, ONLY.
Then back off 5 to 6 notches or clicks.
If you hear any dragging, it won't be the shoes, but it will be the magnet dragging on the armature plate.
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller incompatibility? Flying Gypsies Brakes & Brake Controllers 7 10-31-2011 12:41 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
