Old 08-26-2007, 10:57 AM   #1
1968 26' Overlander
Eureka , California
Question New Brake electrical hookup
Yesterday I installed new axels under my '68 Overlander. The brakes I ordered are drum brakes and the electrical hookup that came with them are two white wires thru the backing plate. The old brakes had one black wire and one white wire. Does it matter which wire I hook up to the black wire or the white wire? By the way, the new axels raised my coach between 4 to 5 inches. I can't wait to get her on the road and see how she handles. Thanks for your help.
Bobz Hog is offline   Reply With Quote
Old 08-26-2007, 11:45 AM   #2
Images: 59
It doesn't make any difference to the magnet which is which.
Old 08-26-2007, 02:38 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Disregard his signature for this topic
I concur with the man from Minnesota.
Tom
Old 08-26-2007, 03:38 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Do 'em all one way or the other. If you mix black and white wires you're sure to end up in a gray area!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-26-2007, 03:50 PM   #5
TomW's Avatar
1967 26' Overlander
Foghorn Leghorn says
That's a joke, son.
You can mix & match wires.
Tom
Old 08-27-2007, 12:48 PM   #6
1968 26' Overlander
Eureka , California
Thanks for your advice. Trailer wireing is new to me and I keep thinking positive and negative connections like in home wiring. I should have known there wasn't a negative wire since there is a ground. Both white wires are positive as I understand it. Man, I've got a lot to learn about these things. By the way, the PO rewired the whole brake system and when I opened the access door under the front of the trailer, I found a bird's nest of wiring with alot of electrical tape holding the connections together. I really need to straighten this out before I go too much further. I bet this could be one of the reasons my rear left stop/turn light doesn't work.
Old 09-03-2007, 05:35 PM   #7
1989 34' Limited
toronto , ontario
Negative and ground are the same thing in North America that is zero potential between the two points.
Dont assume that black is ground and white is positive, because assume will make an ass of you and me.
The white on my Airstream is negative, why I dont know.
good luck
drive safe
letsgo123 is offline   Reply With Quote
Old 09-03-2007, 05:42 PM   #8
TomW's Avatar
1967 26' Overlander
Originally Posted by letsgo123
Negative and ground are the same thing in North America ...
Is South America different?
Just kidding.
Tom
Old 09-04-2007, 05:29 PM   #9
1968 26' Overlander
Eureka , California
Well, after going through the wiring one more time, the black is definately the "hot" wire with the white being negative. The two wires coming out of the brake drum are white, so I picked the upper wire on all of the wheels and connected it to the black wire feeding each wheel and the bottom wire to the white. It all seems to be working. Now I have to get to the dreaded rear floor replacement.
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
