Curious, I recently had to change a tire. My '78 Argosy is set-up with bolts. I've had cars with bolts and cars with studs. On whole I'd say my preference was with bolts.
However ,the wheel on the Argosy was a pain in the drivers seat
I'm wondering if I have the right brake drums or possibly something else has been swapped out from stock. On all the cars I've had with bolts when you stuck the tire up there it was centered on the hub. Although it was somewhat of a three handed operation to line up the first one or two bolts it was easy to keep the wheel in place with one had. On the trailer there seemed to be about a 1/4 of slop with really nothing helping to center the rim on the drum.
Looking at new wheels I noticed they listed the bolt pattern ( # x BCD) and a second dimension which I assume is the opening in the center. Anyone know what this should be and if it addresses the centering issue? If not then I'll definitely be switching to studs and acorn nuts.
Another related question, anybody ever had to replace drums on their trailer because of wear? On the rear of a car or truck the drums should be good for 100,000 miles or so. Curious as to what sort of life to expect from the trailer and if storage tends to be hard on the brakes as well as the tires.
-Bernie
