Old 11-12-2013, 09:02 PM   #1
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
New axles and disc brakes
This summer I replace the axles on both trailers. The 1954 Liner had new spring axles when we picked it up in 2005 in Florida and the 1979 Safari had the original torsion axles. Uwe at Area 63 Productions installed new torsion axles and 12" disc brakes on the Liner, since that involved removing the springs and welding new plates for the torsion axles.
My son and friends replaced the axles on the Safari and installed the new 12" disc brakes. Uwe completed the brake lines and actuator installation.
You can see the that the new axles raised the Safari up about 1 1/2". It was necessary to jack the Safari up in order to reinstall the wheel after the new axles were installed.
The axles had the low profile brackets and all four holes on both axles had to be redrilled to fit. Not a bolt in experience.
Here are a few pictures of the process and a comparison of the 10" brakes from the Liner to the 12" brakes on the Safari.
Bill
ID:	199875   Click image for larger version
Just my personal opinion
Old 02-22-2014, 06:58 AM   #2
Boerne , Texas
Hey, that's a good idea, I didn't know someone offered disc brakes that would fit this wheel well. I'm curious of how the disc brakes actuate? The old brakes are electric but aren't the disc brakes hydraulic? How do they get applied?
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 02-22-2014, 08:22 AM   #3
Disc brakes can be added to most any trailer.
The hydraulic's are in an "actuator".
The actuator has the fluid and pressurizes it on demand.
