Old 06-18-2019, 06:19 PM   #1
Freedomrider's Avatar
2013 30' Classic
Lakeland , Florida
Never R Lube, Brakes & Inspections
Hi All,
I am in much need to find a Authorized Dealer or a qualified recommendation for someone to Inspect and/or repair (if necessary) any issues on my 2013 Classic 30' Airstream brakes. I live in Lakeland, FL (Central Florida).
I am not having any issues but I am years overdue for a inspection. I am close to Airstream of Tampa, but I have been refused service there several times. I suspect because I did not by from them. All others trailer shops, I know, say they do not work on Airstreams.
I did find one Airstream Dealer who would work on it but said if nothing is wrong don't worry about it until you have some issues. I would rather try to avoid any problems if possible.
Any recommendations or help would be much appreciated.
Thanks for any help.
Freedom Rider and Roadrunner
2013, 31 'Classic
2012, 2500 Ram Longhorn, Air Safe, Reese Hitch
Freedomrider is offline   Reply With Quote
Old 06-18-2019, 07:11 PM   #2
2017 25' Flying Cloud
Lawrenceville , Georgia
JD SANDERS / Gainesville.
TANZER099 is offline   Reply With Quote
Old 06-18-2019, 07:54 PM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
The procedure is straightforward:
http://www.dexterpartsonline.com/fil...20Bearings.pdf
It’s basically jacking up the trailer, rotating the wheel, checking for play, making sure the wheel spins freely without bumps and noises.
Ted S. is offline   Reply With Quote
Old 06-18-2019, 07:55 PM   #4
2015 30' FB FC Bunk
My apologies, I see you are concerned about brakes, not bearings.
Old 06-19-2019, 06:22 AM   #5
2013 30' Classic
Lakeland , Florida
Thanks Ted S., Very helpful information. I would like to have it all inspected while someone is in there. I am just not able to do this myself because of medical reasons. I will just keep looking or someone may be able to help with your information.
Thanks again.
2013, 31 'Classic
Old 06-19-2019, 07:20 AM   #6
2013 30' Classic
Lakeland , Florida
FYI, just found an Authorized Dealer in Orlando, FL. for Dexter. It's Davids Trailer, 407-293-2922.
Hope this helps anyone else that is looking in this area.
2013, 31 'Classic
Old 06-19-2019, 10:12 AM   #7
DonRich7878's Avatar
2013 30' Classic
Key West , Florida
Its basically jacking up the trailer, rotating the wheel, checking for play, making sure the wheel spins freely without bumps and noises.
At around 100K miles on my 2013 classic, new bearings were installed.
DonRich7878 is offline   Reply With Quote
Old 06-20-2019, 06:18 AM   #8
2013 30' Classic
Lakeland , Florida
Glad to know that I am not alone. I am at about 115,000 miles. I have not had any issues up to now or had any work done. I just need to know from a professional where I stand and what to look for in the future. Hopefully, David's Trailer in Orlando, FL will be a go to place to address any issue concerning my Running Gear.
Has anyone gone to David's Trailer before? If so, what was your experience.
2013, 31 'Classic
Brakes and Never Lube Seals paiceman Wheels, Hubs & Bearings 131 04-23-2019 06:49 AM
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 11 10-09-2017 09:06 PM
Dexter Never-R-Lube Inspection and Maintenance Ted S. Wheels, Hubs & Bearings 24 04-29-2017 05:09 PM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 07:59 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 04:35 PM
