Old 04-10-2019, 06:13 PM   #1
2011 28' Flying Cloud
Orillia , Ontario
Nev R Lube
Good evening
My 2011 flying cloud has Nev r lube bearing and have to replace brakes and hubs. Does any one know of a alternate source for these hubs since Dexter wants a lot of money for these. Like $600 here in Canada.
Or would spindles need to be replace and conventional bearing used instead.
Rust is offline   Reply With Quote
Old 04-10-2019, 07:19 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Nev-R-Lube is proprietary to Dexter, and is only available from Dexter and their dealer network.
Old 04-10-2019, 07:28 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Nev R Lube is just a cover over the outside of the bearings. It is spring loaded. When you shoot grease into them, they push the grease back into the bearing and races on a continual basis. They work, but I have also seen them push grease past the rear seals and contaminate the brake surfaces.
I would just put on standard hub caps (for $2) and have the bearings packed every 10,000 miles or so. YMMV.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is online now   Reply With Quote
Old 04-10-2019, 07:30 PM   #4
1993 21' Sovereign
You are confusing Bearing Buddies with Nev R Lube bearings.
Old 04-10-2019, 07:34 PM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
No. I actually had Nev R Lube on an enclosed car trailer and they did that. Now, in full disclosure, I probably should have serviced the seals sooner, but we all think "Well, I don't need to worry about the bearings", which is when we usually change the seals. Just saying...
DaveP
Old 04-10-2019, 07:36 PM   #6
1993 21' Sovereign
No. I actually had Nev R Lube on an enclosed car trailer and they did that. Now, in full disclosure, I probably should have serviced the seals sooner, but we all think "Well, I don't need to worry about the bearing", which is when we usually change the seals. Just saying...
I will refrain from typing what I am thinking right now.
Google "EZ Lube Hubs"
Google "Nev R Lube Bearings"
Google "Bearing Buddies"
and report your findings back here.
Old 04-10-2019, 07:43 PM   #7
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I stand corrected. It must have been bearing buddies... My mistake.
DaveP
Old 04-11-2019, 06:24 AM   #8
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Are the hubs damaged or do you just need new bearings?
Iíve looked into replacement bearings and pretty sure Timken Set 49, yup thatís the part number fits these hubs. And yes they can be replaced.
https://www.rockauto.com/en/parts/ti...l+bearing,1672
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-11-2019, 06:28 AM   #9
dznf0g's Avatar
Oswego , Illinois
Holy moly, Gary! Have you confirmed that this is a correct crossover part? That's like 20% - 25% of the price from dexter
-Rich-
Old 04-11-2019, 06:47 AM   #10
GCinSC2's Avatar
http://www.showmetheparts.com/timkenmobile/
I did a lot of research a while back, lots of cross ref and research. I donít have the file at my desk right now.
The link above should take you to a user friendly Timken online catalog.
This is a common design wheel hub bearing.
I do have Neverlube disc hub and bearing at home and should be able to measure and visit old records but not until this weekend.
Possible see if dexter has size on their website and compare.
S/OS #001
Old 04-11-2019, 06:50 AM   #11
dznf0g's Avatar
Oswego , Illinois
I have a Dexter spare bearing out in the trailer, but don't have access to proper micrometers anymore. I'll pull it out and do some number cross referencing, but I recall I didn't get very far by that method (albeit, that was about 8 years ago.)
-Rich-
Old 04-11-2019, 07:07 PM   #12
Orillia , Ontario
hubs
The bearings are still good I just needed new hubs (drums) or I will try to resurface these for now. Can't seem to find a replacement hub for that spindle other then dexter.
Old 04-11-2019, 08:58 PM   #13
dznf0g's Avatar
Oswego , Illinois
Find a good dirty shop who understand how to finesse a lathe. Dont buy new hud/drums until you find a barn shop. That's all I got or say
-Rich-
Old 04-11-2019, 10:07 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
No...never-lube is a sealed bearing..never lube...
Old 04-11-2019, 10:12 PM   #15
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Good evening
Turn the drums?....I didnít turn mine.they were good...I had to turn the area where the magnets rub...new backing plates with pre installed shoes and magnets....from e trailer....on sale...$96 a pair...
Old 04-11-2019, 10:28 PM   #16
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Dexter. 42mm. #031-073-03........jrm 4249. Timken USA....I paid $ 105.....I did find them cheaper overseas...
Old 04-28-2019, 06:15 PM   #17
Orillia , Ontario
Thanks for feed back
I had hubs resurfaced and new bearings installed and put on new brake assemblies. Whole job was $1200.00 Canadian. ($888.00 U S D)
Did the labour part myself.
I thought not bad for an 8 year old trailer, with 60000 KL on it.
But wanted to thank you all for input.
George
Old 05-11-2019, 12:59 PM   #18
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I have a 2009 25í that has never-lub bearing and disk brakes. Did AS go back to drums and lub bearings
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 05-11-2019, 03:11 PM   #19
1986 31' Sovereign
Miami , Florida
Okay, I am thoroughly confused. Nev R Lube bearings are oil soak bearings, no? What could cause them to need replacement after only 36000 miles?
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-11-2019, 03:21 PM   #20
1986 31' Sovereign
Miami , Florida
Never mind, looked it up. Not an oil bath but still, I wish I had them on my old Sovereign -- the annual repack is a p.i.a.
Young, lovely bride
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Dexter nev-r-lube failures Jammer Wheels, Hubs & Bearings 44 04-26-2015 07:42 AM
centramatics and nev-R-lube bearings gtc6452 Wheels, Hubs & Bearings 14 08-09-2013 09:59 AM
NEV-R Lube Hubs stefario General Repair Forum 1 05-15-2012 07:07 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
