Old 04-02-2008, 10:18 PM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Need to redo the brakes on my Tradewind
Can anyone recommend a good place to get the loaded brake linings? I am not an accomplished brake repairer, but I do OK. How long should I expect it to take to replace the brakes on 4 axles?
chuman70 is offline   Reply With Quote
Old 04-02-2008, 10:38 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
With loaded backing plates, you might spend about 45min to one hour per wheel.
Hopefully less...
A trailer shop in your area might be able to get your parts for you, or try one of the online suppliers.
Uwe
www.area63productions.com
Old 04-02-2008, 10:43 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
before you replace brakes, you might check to make sure your axles are still good, ours weren't so we updated everything at once. It feels good knowing all running gear is new.
goransons is offline   Reply With Quote
Old 04-03-2008, 06:33 AM   #4
Images: 59
uhhhhh. . . . . Redneck Trailer Supply?
Old 04-03-2008, 04:06 PM   #5
The following article will teach you how to check out your axles in just a couple of minutes.
Dura Torque Axle
Using your original hub and drums on a new axle, is not a good idea, since yours are known to be way out of balance, primarily because they are 2 piece.
For sometime now, hub and drums are "unicast." They still are not in true balance, but close to it.
The originals are usually way out of balance.
Old 04-03-2008, 10:31 PM   #6
1974 25' Tradewind
Andy,
My axles are still OK right now. I still have a slight downward angle on them and they are not fused as all 4 passed the raising test by moving about 2-3 inches when removed from pressure. I would think I probably will need new axles in the not too distant future, but they will do for another 2-3 years I hope. Maybe my A/S budget will have a little more gusto then.
Old 04-03-2008, 10:51 PM   #7
Andy,
As long as you keep you eyes on your present axles, you will be fine.
The axles that fail quickly, are those used on the Caravel models from 1968 and older.
The rubber rods in the 73 and older trailers, regardless of length, will also fail in time.
The biggest cause of those failures is "lack of use."
The second cause is the composition of the rubber, that fails in time.
Keeping a watchful eye on yours is the best that you can do.
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 09:42 PM
electric brakes on 1976 Trade Wind pcaines Brakes & Brake Controllers 8 07-16-2007 09:41 PM
Need help on trade wind mercury7 1959-69 Tradewind 57 10-27-2006 06:38 PM
'61 Trade Wind DiMi Member Introductions 7 08-01-2006 03:00 PM
