Old 10-11-2010, 07:13 PM   #1
1998 34' Cutter Bus w/slide
hull , Quebec
Need help on how to access brake fluid reservoire on a 1997 airstrams cutter
I needed to add brake fluid and on my cutter 7.5L Ford I could unscrew the cap but impossible to fill up there is no room at all.There must be a way.I see a door on top but its right above my front windshield dash >>>>>help would be nice
thank you
poloharvey is offline   Reply With Quote
Old 10-11-2010, 07:35 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Me I'd use a clean piece of hose.
Old 10-11-2010, 10:23 PM   #3
hull , Quebec
I did fill it up with a small hand siphon but I am curious to know how its really done and also a brand name like Airstream that as been in the market for so long have done it this way.
Its the same to fill the engine oil you need good imagination to figure a way to put in your oil.....
Old 10-11-2010, 10:28 PM   #4
hull , Quebec
Also the brake fluid reservoir is in front off the motor but you canot see it you got to bring your head inside and its above you engine hood and you can barely used your finger to removed the cap so you got a pump it up to the reservoire almost 1 feet up so you canot used a funel there is no room....
1997 Ram 1500 Brake light problem wbrownrr Tow Vehicles 4 09-26-2009 10:03 AM
cutter 1997 ford 460 cutbrain Land Yacht/Legacy Motorhomes 7 08-20-2009 06:07 PM
1997 Airstream Cutter ONLY 32K MILES! Ford 460 Banks!! eBay Watch Airstreams on eBay 0 02-21-2009 05:30 PM
Brake Fluid Reservior Bedford Land Yacht/Legacy Motorhomes 3 07-15-2007 03:06 PM
1997 A/S Cutter 35 (DP) dleslie125 Airstream Motorhome Forums 1 03-30-2003 11:53 AM
