Old 10-03-2006, 09:13 AM   #1
1970 27' Overlander
Colo Spgs , Colorado
My K-H Brake Unit & the De Soto
Hola Class
It makes me think of the movie called " The Long-Long Trailer".
This K-H brake controller takes attention and thought to use. It is mounted just under the steering post and if I feel the need to use it, I must swing the braking arm from the resting position to the braking of the right. Yes, there is a knob to up the electrical feel. This unit is simple; do not physically move the braking arm and you do not have the trailer brakes working. If you are shy, the trailer brakes do not do much. If you swing too much the trailer brakes will lock up now.
Have any of you ever came across a unit as this other than a antiquic show ?
Oh yeh, it looks at home in the 47 De Soto.
Rodger & Gabby
COS
Rodger with a D is offline   Reply With Quote
Old 10-04-2006, 10:36 AM   #2
1960 24' Tradewind
santa barbara , California
Hello Rodger ,
My 68 international travelall had the KH controller and resistor setup .I have
removed it in favor of the prodigy .I still have it on the shelf in the garage .
It too looked right under the dash of the IH ,but thought a newer controller
would be better ,I don't know for sure really ,it may haver been just fine .
Scott
scottanlily is offline   Reply With Quote
Old 10-09-2006, 01:34 PM   #3
1970 27' Overlander
Hola Again Class
I feel that I failed to say this oldie does not have a brake line hook up ability to it. It is only the electrical part that gets the in-put of how much brake action from the knowledge or experience of the driver by activating the arm under the steering post.
Rodger & Gabby
COS
Old 10-09-2006, 06:59 PM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hola, Rodger,
Cool. It IS just like the Long, Long, Trailer, so just keep repeating "First the trailer brakes, then the car!"
By the way, which De Soto can tow a '27 uphill? (I'm a child of the sixties, and there were darn few De Sotos left running then, as I remember.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
