Old 08-10-2013, 03:07 PM   #1
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
My brakes suck
On an extended road trip in the western states. Never had much of a concern with my brakes back home in eastern Canada. But in the serious downhill grades of the rockies and other assorted ranges I find that I'm relying far too much the TV brakes.
I adjusted the shoes but still not much of an improvement. Measured the voltage and current. All looks good.
I'm using the integrated brake controller in my 2012 F150. With the brake controller set to 8, the measured current is 10A.
Thinking there might be something wrong with the brake mechanism I overnighted new self adjusting units from Inland RV. (Thanks Andy) and installed at our campground at Mammoth Lakes, CA.
While better I'm still running with the brake controller on max gain. (10).
I'm at a loss as what to do next. The only thing left left to change are the hubs.
Thoughts ?
MaxTow is offline   Reply With Quote
Old 08-10-2013, 03:13 PM   #2
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
I'm not sure what TV you have, but have you tried using the transmission to help? Maybe take it out of overdrive or use a lower gear? Just a thought.
mopariac is offline   Reply With Quote
Old 08-10-2013, 04:09 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The gear you climbed the hill in is the gear you go down the hill in.
If you are descending a hill in D you may loose the the brakes altogether due to over heating.
Self adjusters will not correct the problem. If your TV does not have a Tow Haul Mode gearing down or an exhaust brake are the first 2 choices.
If you have Tow Haul tap the brakes just as you start down and the trans will come down one gear. If you start to gain speed in that gear hit and hold the brakes to cause slow down and the trans will comes down another gear. When using Tow Haul watch the engine RPMs and don't let it over rev. The Tow Haul will only do so much and brakes are required after that. If you have to use the brakes because of over rev stop all together and start off again in a lower gear that will hold your speed below the point of increasing speed.
2004 Excursion 4x4
Old 08-10-2013, 04:13 PM   #4
1981 31' Excella II
New Market , Alabama
Well can you get the trailer brakes to lock? If not then I would say you have trailer brake problems. You need to check voltages at the brakes themselves to make sure you are getting enough current. Conventional brake controllers are on/off and are not proportional. I don't know how your F150 controller works but you might want to read up on that. Drum brakes will overheat pretty quick and if you have your foot on the brake they are full on the whole time unless your controller is proportional. I have never been impressed with drum type trailer brakes.
Perry
Old 08-10-2013, 05:20 PM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The retrofit of disk brakes for your Airstream at the factory will likely melt the AmEx card. There are few dealers that have even a smidgen of knowledge on how to work on the trailer version of Disk Brakes.
Old 08-10-2013, 05:37 PM   #6
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
As mentioned above, go downhill in Tow/Haul mode - it will help.
I was towing today in rather hilly Vermont, and was amazed at how the engine braking will keep the whole rig at 50 mph down some rather steep grades.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 08-10-2013, 08:27 PM   #7
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Are all the brales working on your trailer?
A brake controler like the Prodigy has several settings for trailer size and anticipitation. I think a new controler is in order.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 08-11-2013, 04:07 AM   #8
richinny's Avatar
2011 34' Classic
are the right and left brake assemblies on the correct sides?
Ricky
Old 08-11-2013, 05:30 AM   #9
LFC
Memphis , Tennessee
Thoughts ?
You can not rely on trailer brakes on long down hills....
You have got to slow down and use the transmission along with occasional use of the trailer brakes to keep your speed under control.
I'd suspect you've fried your brake shoes and possibly scorched your brake drums.
LFC is offline   Reply With Quote
Old 08-11-2013, 07:51 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
LFC is absolutely right. Relying only on trailer and TV brakes in the mountains in a recipe for damage, possibly disaster. Slow way down before heading downhill, and keep it that way with your transmission; use your brakes only occasionally.
Lynn
Originally Posted by LFC View Post
You can not rely on trailer brakes on long down hills.... You have got to slow down and use the transmission along with occasional use of the trailer brakes to keep your speed under control. ...
WBCCI 21043
Old 08-11-2013, 08:26 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Agree with Eubank, LFC and others.
Before I would take another trip, you might consider servicing the brakes on your AS.
We don't know mileage on your AS or previous use. If you don't know how, take to RV dealer. Brakes are standard enough a reputable dealer can service.
Let us know..
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-11-2013, 08:31 AM   #12
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
It's all been good advice so far. I'd like to add slow down. Don't do the posted speed limit on the down hill side. It's figured out for a car in good weather conditions, not for larger vehicles that may be towing. Crest the larger hills going 5-10 mph slower & try to maintain the slower speed all the way down.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 08-11-2013, 10:04 PM   #13
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
Thoughts ?
I recently upgraded from a 2008 F-350 to a 2011 F-350 and a newer to me airstream with hydraulic disc brakes. My first trip the brakes didn't work well or smoothly and I had the gain set for 10. I figured out that I could select electric or electric over hydraulic and as soon as I changed it to electric over hydraulic it worked great. Maybe your computer is set for electric over hydraulic and you need to change it. I can access the settings under truck applications.
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 08-11-2013, 10:44 PM   #14
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Braking Controller
Just a thought...
I tow and brake without a problem. I use a Tekonsha Prodigy® P2 Electronic Brake Controller. it controls the Panamerica's stopping without fault. It was installed by CanAm RV in London, Ontario. Andy's knowledge and people are great on any towing issue. Give him a call.
Urbanologist is offline   Reply With Quote
