Old 10-22-2003, 08:20 PM   #1
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
my '77 land yacht w/o brakes
Hi folks,
I am needing info/help with the braking system on the '77 land yacht I just purchased. After discovering I had no brakes on the trailer(while towing it ), I have since removed the wheel calipers and had them rebuilt. However, Im still without brakes. I assume my problem is with the master cylinder or the vaccuum booster attached to it. Question, can either be rebuilt as the wheel calipers were? I do hear air passing through the vacuum booster but do not know if it is effecting any actuation to the master cylinder attached to it. Could the membrane in the booster be leaking? Could the the master cylinder be bad and allowing fluid to bypass the the pump? I "m needing suggestions on next possible step. Either remove the whole actuator from the tongue of the trailer and replace or have the existing one rebuilt. any suggestions would be greatly appreciated.
sincerely stuck in Indiana!
wayne.yl is offline   Reply With Quote
Old 10-22-2003, 08:35 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
There's quite a bit on here about the vacuum disc brakes, which are supposed to be like The Best Trailer Brakes Ever. You do have a vacuum line run back to the trailer from your engine, right?
Andy knows all about 'em - I expect he'll pitch in here in a minute.
I've got a couple of shots of the service manual pages for those brakes - can't do it tonite, but maybe I could email you a couple of pages this weekend. PM me if you're interested.
I do think if you're hearing air rushing thru the booster, that the diaphragm might be bad....
-Don
Old 10-23-2003, 08:37 AM   #3
laurandwayne.
When you hear air (actually vacuum) noise when parked, with the engine running, it tell you that the "sync" valve is shot.
The sync valve is at the bottom of the booster.
We rebuild the sync valves with same day turn around.
Old 10-23-2003, 09:05 AM   #4
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Thanks for the info,
I may have geen a bit unclear before when describing the air or vacuum sound. I do have the vaccuum line connected to the brake booster on my tow vehicle, but I hear air passing through the trailer booster only when I apply the brakes. Also the fluid level fluctuates in the resevoir somewhat as I apply the brakes. After installing the rebuilt calipers, I tried to bleed the lines but could not get enough pressure to do so. I do not get enough hydraulic fluid back to the calipers to operate them. I hope this makes sense as I know just enough about this subject to be confused. And yes any pictures or access to any service manuals would be helpful.
Thanks again
Wayne
Old 10-23-2003, 09:16 AM   #5
laurandwayne.
You are again describing a bad "sync" valve.
Replacements are not available, but we do rebuild them.
We suggest that you call Helen Davis at 937-4928885 for a "service manual."
That manual covers many subjects, along with "how to" for many areas including your disc brakes.
Old 10-23-2003, 09:31 AM   #6
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Thanks Andy,
I have already taken your advice and ordered a svc manual from helen in Ohio.. Given what little I know about my "new trailer" I believe it will be the best $75.00 I could spend. Regarding the sync valve, What is my next step.. Do I send the whole booster/ cylinder to you?
Wayne
Old 10-23-2003, 03:34 PM   #7
laurandwayne.
If your in a hurry, you can next day just the "sync" valve to us, along with your name, address and phone number.
We will call you for your CC info, overhaul the sync valve and have it on its way back to you the same day.
Or, if time is not a problem, send us just the "sync" valve, along with the other info, and we will overhaul it within a day or two and return it to you via UPS or Airborne ground service.
Old 11-06-2003, 08:40 PM   #8
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
more hydraulic brake questions
Andy,
perhaps you might know?
Since recieving your advice on my sync valve question, I have removed the booster, master cylinder and sync valve. I found a local fellow heere in Evansville that may know more about hydraulic/vacuum brakes than anyone I know, except you of course. Anyway after describing to him my brake problem, (not getting pressure to the calipers), he couldn't wait to tackle the job. He took the manuel I purchased and proceeded to rebuild the booster, and cylinder. After that he applied vacuum to the system and tested the sync valve to see if it was functioning correctly. Turns out it was. I reinstalled it on the trailer, bled the brakes and took it for a test run. I now have brakes but my question is, how much braking power should I have? When I apply the trailer brakes only I feel the rig slowing down but I do not get maximum braking power. Is there adjustments or is this all I can expect? Any thoughts?
Wayne
Old 11-07-2003, 09:35 AM   #9
Wayne.
Still sounds like the sync valve is not functioning correctly.
It governs the amount of braking power.
The other could be that the shop did not bleed the brakes completely.
Old 11-08-2003, 05:54 PM   #10
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Unhappy Andy I found my braake problem
I found the brake problem on the land yacht.
Turns out when I tried to bleed the brakes again according to the svc manuel, I found a leak at on of the fittings near the wheels.
Its at at the T where teh brake tubing splits to the two wheels.
Turns out the fitting is split and I have been every where looking ofr a replacement but no luck. Its a reducing fitting that has a female end on both ends. Any suggestions on parts place that might carry such a fitting? thanks
Wayne
Old 11-08-2003, 06:44 PM   #11
Some of the larger brake shops - especially those that work with larger trucks - can fabricate anything you will need for hydraulic brake systems.
Mark
Old 11-09-2003, 01:16 PM   #12
Laurandwayne
We do not have that fitting.
You will probably have to resort to having one made, unless you can find someone that has removed the disc brakes and saved the parts.
Old 11-09-2003, 03:55 PM   #13
Mike B's Avatar
1977 23' Safari
1976 31' Sovereign
Robbins , California
Brake fitting
Wayne,
If you will describe where the T is located and the approx size of it I may have what you are looking for. Our trailer had the disc brakes at one time but the PO swapped them out for electric brakes. I still have some of the brake lines attached to the frame and maybe I have what you need.
Mike B
Mike B is offline   Reply With Quote
Old 11-09-2003, 05:23 PM   #14
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Brake fitting
Mike
The fitting I need is located directly behind the wheels on either side of the trailer. Your can see the fitting by looking in between the 2 tires. The brake line runs along the frame until it splits at the "T" fitting that carries fluid to both discs. I have the "T" fitting but the reducing fitting attached to the "T" fitting is the one that split. You can identify the fitting because it is on the side of the "T" that comes from the master cylinder and has the largest tubing attached to it. I hope this is not too confusing.
Thanks for the reply. Let me know if you find anything.
Wayne
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 08:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 08:00 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
