Old 02-15-2016, 10:06 AM   #1
ole81's Avatar
1981 31' Excella II
Richmond , Texas
magnetic brake actuator question
I was doing maintenance on our 1981 Excella II and discovered that the magnetic brake actuator is flush with the three screws that hold it together.
Is this normal or should the screws be recessed?
Also, any recommendations of a source for new ones would be appreciated.
Thanks for looking.
Bob and Gail
Name:	Magneticbrake actuator.JPG
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 02-15-2016, 10:36 AM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would think that magnet is worn out. The ones on our Avion are not that style, but anything worn down to the screws is not good.
I ordered brake assemblies from Southwest Wheel http://www.southwestwheel.com/store/...ssemblies.aspx
They also sell individual parts for electric brakes.
Another source is etrailer.com https://www.etrailer.com/dept-pg-Trailer_Brakes.aspx
Not sure if they sell individual parts or not.
If the brake assemblies on your trailer are worn, I wouldn't hesitate ordering the complete assemblies and replacing them. They are very easy to replace.
ďWhatís good for me may not be good for the weak minded.Ē
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 02-15-2016, 12:52 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
As stated above that brake magnet is worn out. Not sure that style (round) is available either. The updated replacement would be oval in shape.
And as stated if the friction material is worn out as well you can be money ahead by buying a loaded assembly instead of pieces.
>>>>>>>>>Action
Old 02-16-2016, 06:35 PM   #4
ole81's Avatar
1981 31' Excella II
Richmond , Texas
You are right.....the round actuator is hard to find. Will start exploring replacing the whole assembly.
p.s. I compliment your taste in toys....In '68 I had a '66 Merc Colony Park wagon and in the 80s I had a '67 Linc conv.
31' 1981 Excella II
or
Old 02-16-2016, 09:45 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Thanks!!! I have a couple of others not listed.
The round magnet was superceded by the oval magnet. Not sure how long ago and it may be a decade or more.
>>>>>>>>Action
Old 02-17-2016, 10:35 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
It would probably be a good idea to make sure your braking linings are not worn out also...If they are really worn badly, your bst bet is to replace the entire backing plate assembly. They come with all new components, (magnets, springs, linkage, and linings). The cost is considerably less than the individual components.
Depending on where you buy them they usually run from $75.00 to $90.00/wheel. It's a simple replacement, just cut the wires to the magnets, take the 4 bolts off and the old backing plate should come off easily.
Then, just reverse the procedure with the news one, connect your wires, get the brake spoon and adjust them, and you are good to go...
Good luck!
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 02-17-2016, 11:02 AM   #7
1998 30' Excella 1000
Livingston , Texas
If you have not already, take a look at the drums and make sure they are not badly scored. New magnets will not work well if they are.
As I understand it, it is getting harder and harder to find a shop that can re-surface brake drums. On a +35 year old rig would folks just recommend replacing them, if scored?
Siegmann is offline   Reply With Quote
Old 02-17-2016, 11:13 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
Time you buy magnets and shoes, while your are in there, it is cheaper to by the complete backer plate.
12in. assemblies start at $32.00. Magnets often go for over $25.00
looks like you just got in there in time. The drum should be OK because the magnet is not deeply scored and the screws did not get to the drum yet.
2004 Excursion 4x4
Old 02-17-2016, 11:34 AM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Complete brakes with new backing plates and magnets are about $. 58, easy bolt on...
Old 02-17-2016, 12:03 PM   #10
1967 26' Overlander
Spartanburg , South Carolina
I am not familiar with your model A/S. I'm a "67 vintage guy. Just wanted to tell you that some 6 or 8 years ago, I had a brake adjuster retainer spring break while traveling. The pieces wedged under the brake shoe destroying it. Thankfully, there was a utility trailer manufacturer a few miles away who stocked Dexter brake assemblies. The new Dexter assy. bolted right on my Henschen axle and the 12" brake matched my old drum exactly. I bought 4 of them for a little less than $200. I didn't notice where you are located but you can order Dexter brake assys. from any Dexter distributor such as Newera in Taylors, SC or Red Neck Trailer Supplies in Lincolnton, NC. There is probably one near you.
Jacob D is offline   Reply With Quote
Old 02-17-2016, 07:24 PM   #11
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Thanks for all the replies.
We are located just west of Houston, TX.
My research has found, as mentioned in the replies, that the logical step is replace the entire assembly.
Fortunately, the shoes are not down to the rivets, so my drums are OK.
This afternoon I visited my local trailer dealer and he said he can get these Kelsey-Hayes actuators...but they would cost $59.50 each, whereas, a standard Dexter assembly would be the same price.....and self-adjusting sets would be $79.
That seems to be a no-brainer to me.
31' 1981 Excella II
or
Old 03-03-2016, 12:36 PM   #12
ole81's Avatar
1981 31' Excella II
Richmond , Texas
I understand the actuator was a Kelsey-Hayes.
I don't know if the backing plate is K-H or whatever..
I went to the local trailer shop and they carry Dexter products.
Can anyone tell me if the 5 hole pattern is industry standard...since 1981????
I am reluctant to take Ole81 over, and have it sit for an extended period of time while they search for replacement parts.
31' 1981 Excella II
or
Old 03-03-2016, 01:34 PM   #13
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Looks like 4 bolts, will probably interchange, only takes 5 minutes to take off and see, 58$ here in billings....
Old 03-04-2016, 08:10 PM   #14
ole81's Avatar
1981 31' Excella II
Richmond , Texas
I should have clarified.....
The backing plate on Ole81 is a 5 lug and the bottom two are not evenly spaced.
Under normal conditions, it would be a trivial job to remove the 5 nuts...but these nuts have not been off since the rig was built. Needless to say...lots of rust, so extreme care must be taken to avoid rounding off the nuts.
Still anxious to hear if they swap out for Dexters....
Thanks for looking...
31' 1981 Excella II
or
Dexter E/H Actuator to replace ActiBrake Actuator nickmeloy Brakes & Brake Controllers 32 10-22-2014 08:58 AM
surge brake actuator? junkyardawg Brakes & Brake Controllers 8 02-18-2012 02:59 AM
Dexter or Carlisle brake actuator Tim Attridge Brakes & Brake Controllers 2 04-03-2011 10:59 AM
Stromburg Hydraulic Brake Actuator aprimosch Brakes & Brake Controllers 4 06-19-2007 01:32 PM
Magnetic Brake Controller MattyBoy Brakes & Brake Controllers 3 01-04-2003 01:29 PM
