Old 04-25-2009, 09:46 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A good interim fix would be to use sections of 1/2" air hose, or other reinforced hose, around the brake hose, so the rubbing will happen on that rather than the brake line itself. Cut and slit the reinforced hose lengthwise, slip it over the brake hose, and ziptie it in place. It is crude, but effective, until y'all can afford the braided steel stuff.
Old 04-25-2009, 10:22 AM   #16
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Crude, maybe. It will work though. Thanks for the tip.
Greg
Roadtoaster is offline   Reply With Quote
Old 04-27-2009, 07:28 AM   #17
2007 31' Classic
Kingston , ON
Flex lines crimped
Hi - I got a reply from Airstream - they've agreed to send me 4 new flex lines! But are unwilling to admit that there might be a problem with their design. They say they've sent my photos and complaint on to their "Safety" division.
So I still have to figure out how to reroute the lines so that they are safe. Someone here mentioned maybe putting 1/2" rubber piping around the flex hoses, but unfortunately half the problem is rubbing, and the other half is crimping, so that solution might make the crimping worse.
I bought a 90 dgr elbow yesterday, so I'll try to take a wheel off this week and see whether it might help. And I'll take plenty of photos as I'm going along.
Sorry, my trailer is a '07 (not a '06). But I assume this problem pertains to any recent Classic trailer with disc brakes.
trvler
trvler is offline   Reply With Quote
Old 04-27-2009, 08:03 AM   #18
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Trvler,
Thanks, I anxiously await your progress pictures as I am going to have to do the same thing very soon as our first outing with the '06 is rapidly approaching.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-30-2009, 06:51 PM   #19
DEITZ645's Avatar
Exclamation Removed Brake Lines
Well the rain held off and I was able to get the trailer out of the orchard and into the driveway. I then proceeded to jack her up and remove the tires so I could get at the brake lines. Tomorrow I am going to take the lines to a hydraulic shop in the area and get longer steel braided hoses custom made.
Here are some interesting pictures of the event.
This is a picture of how the road side front hose was rubbing the plastic wheel well.
Here is a blurry picture where you can see how bad the road side front hose was kinked.
Here you can see where the road side rear hose was riding and rubbing under the frame and wheel well.
Here you can also see where the curb side rear hose was riding and rubbing on the frame and wheel well.
I was able to reposition the curb side rear hose so it will not ride or rub under the frame or wheel well. The only problem is it is still to short. As soon as I let the trailer down off the jack it makes the bend in the hose a little tighter than I would like to see it.
Here you can see the curb side front hose that I replaced in the campground last year that started this thread. It is still out of harms way, but I am going to replace it anyway.
This is a pucture of both the road side hoses where you can see the harsh bend they make going into the calipers and the damage caused by rubbing on the frame and wheel well.
When I get the new hoses I will install them, take pictures, post the final outcome.
I urge everybody that has an Airstream with the electric hydraulic brakes to inspect their lines and get them replaced as necessary. Don't just look at them, get your hands on them and feel for any spots where they may be rubbing agains something they aren't supposed to be rubbing against.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-01-2009, 08:02 AM   #20
2007 31' Classic
Kingston , ON
Those lines look exactly like mine (including the hole in one of them!). I jacked up my 31' as well, and now in the process of figuring out how to reroute the lines such that the flex hose originates on the 3" rubberized axle on each wheel. That way the hose can be further out toward the wheel, and flexes along the radius of the wheel motion (rather than getting pulled by the wheel the way it is set-up now). I will try to post some images when I get one wheel done.
Also thought of a cheap, simple way to improve the problem without changing the course of the lines - go get a rubber doorstop and glue it to the inside frame to produce a ramp along which the flex line rubs. You might have to build it up some to meet the plasticized part of the frame which is crimping the hoses. This should redirect the flex hose away from the undersurface of the frame - you'll still have to worry about wear, but shouldn't be as severe as rubbing up against the metal edge of the frame. Just make sure that the doorstop is flush with the frame so that the hose can't get caught in a gap.
Gotta get back to work!
trvler
Old 05-07-2009, 05:40 PM   #21
DEITZ645's Avatar
Custom Brake Hoses
Well my friendly neighborhood hydraulic shop called me yesterday to let me know my new brake hoses were finished. So on my way home from work tonight I stopped and picked them up. I had them made 6" longer and out of braided steel.
I would have started installing them, but it finally stopped raining here and I needed to cut the grass before it needed to be baled. I will post more pictures of the install process and final outcome.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-10-2009, 05:08 PM   #22
2007 31' Classic
Kingston , ON
Finished brake revision
Hi - I finally finished rerouting the brake lines, then bled them (took forever) and tested it all with an overnight this weekend. Works well, and the lines are mostly clear (the front curbside nipple at the caliper is just shy of the lip of the frame!).
Here are some photos I took of the process. Hope they make it clear. I fashioned new flex line brackets from 1.5 " aluminum angle, and fastened these to the 3inch rubberized axle. These brackets were angled slightly to direct the flex line laterally past the offending frame. The rigid brake lines I bought at Canadian Tire (very cheap), and bent them with a bender ($10).
I fastened the rigid lines to the frame with rubber and rivets.
If anyone needs more detail, I'd be happy to post more.
Trvler
Name:	New bracket installed.jpg
ID:	79996   Click image for larger version
Name:	New brake layout street.jpg
Name:	New clearance.jpg
ID:	79998   Click image for larger version
Name:	New flex bracket1.jpg
Name:	New flex bracket2.jpg
ID:	80000   Click image for larger version
Name:	New front street bracketinstall.jpg
Name:	New line rear street.jpg
ID:	80002   Click image for larger version
Name:	New main T.jpg
Name:	Original frnt curbside.jpg
ID:	80004   Click image for larger version
Name:	Original frnt curbside2.jpg
Old 05-10-2009, 07:05 PM   #23
2009 30' Classic
Salem , Alabama
lI lost the road side lead wheel interior break pad. (The retaining pad pin was not secured).Result: Total loss of fluid,total loss of trailer breaking capacity,destroyed lead wheel caliper plus rotor. After addressing that problem. I am sitting in Orlando KOA with a non-functioning refrig,a constantly tripping 20 amp AC breaker. 2009 classic 30 in service less than sixty days.Needless to say my first introduction to the AS life style has been less than satisfactory. I reallymiss my previous RV. I forgot to mention my new refrig was also on recall .also
woppa 4 is offline   Reply With Quote
Old 05-11-2009, 05:18 PM   #24
Pappy's Avatar
2006 25' Classic
Floyds Knobs , Indiana
Deitz645
Due to your post I inspected my flex lines and I found one that was almost wore through. But mine was worn on the tire side as though the tire was rubbing it.
Looked like plenty of clearance but I guess not enough. Went to have a hose made today but apparently the fitting on the end that connects to the metal tubing must be different. The new one leaked at that connection but the old one doesn't. Anybody know if there is anything special about the fittings. I am going to order a new line tomorrow from Airstream or Airstream dealer but I am curious if any one knows?
Also Deitz645 thanks for calling this to our attention I would have missed it.
Pappy
Pappy is offline   Reply With Quote
Old 05-11-2009, 05:34 PM   #25
DEITZ645's Avatar
Installed Custom Hoses
On Sunday I took some time off from yard work and opening the pool to install the new custom braided steel brake hoses on our '06. The install was uneventful except for one loose fitting that proceeded to spray me with brake fluid while we were bleeding the brakes. I made sure the fitting was tight and no more leaks. The new hoses are plenty long enough now and I was able to position them so they WILL NOT rub on the wheel well, frame, or tire. Here are some pictures of hoses on the curb side. The road side looked just about the same.
ID:	80083   Click image for larger version
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-11-2009, 05:47 PM   #26
DEITZ645's Avatar
Originally Posted by Pappy View Post
Deitz645
Pappy
Pappy,
I am glad folks are checking their hoses. If you get the hoses from Airstream I would ask them to send you ones that are 6" longer than the standard hoses. If you have custom hoses made, just take one to the shop and they should be able to duplicate the fittings. Just remember to cover the fittings that hose hooks up to so no insects / spiders try to make a home in them.
For those folks looking for an Airstream part number for the brake hoses, it is...454300-16
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-16-2009, 04:43 PM   #27
1976 27' Overlander
louisburg , North Carolina
Hi I need help with breaks
Not sure if you can help; and truth I need a Bigger truck. I have a 76 airstream I just bought. It is in great condition with the wiring ect./ X retired military man owned. I it hooked to a new Chevy all worked, even electric breaks. I have an 1997 Chevy, Have had problems with the wiring harness. Last year redid all wires to spec, with 6 wires, not 7, but to a 7 way plug. As I also pull a gooseneck horsetrailer. The electric breaks work on the horse trailer/ but not the Airstream? Do I have to have the 7th wire? Wahhh, Been working on it a while and was planing to head to the mountains of nc next weekend. Beth from Bunn NC
Originally Posted by ncbambi View Post
Carl, glad you had a positive outcome to losing your brakes. I had a problem with my brake controller going up into the mountains of NC - not a great time or place! Anyway, stopped at an RV dealer (not an AS dealer) and they wouldn't help (all service techs in meeting), yeah right! The service manager wouldn't even come out to see what the problem could be. So, long story short, I had turned the braking range all the way down to 0 by mistake - turned it up and breaks were there! Glad to know that the breaks were working!
I had a problem with the power jack and Randy from AS was really great and overnighted a part to us also. Every time I have needed AS, they have come through. Sorry to say that the RV dealer in Hendersonville NC (Todds RV) couldn't have cared less.
Is there a retro repair to keep your brake line from rubbing and leaking again?
iy2boogie is offline   Reply With Quote
weekend warriors-rear brakes PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 31 08-03-2014 11:31 AM
Electric trailer brakes Kurt & Eve Brakes & Brake Controllers 9 05-22-2005 04:25 PM
New Trailer Disc Brakes. Inland RV Center, In Brakes & Brake Controllers 28 02-02-2005 05:07 PM
57 trailer with hydraulic brakes Mariner Brakes & Brake Controllers 7 10-28-2003 11:34 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
