Old 06-18-2013, 11:12 AM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by flynmike View Post
....... The manager at the shop said the fitting might not have ever been tightened up properly and it finally worked loose enough to start leaking.
I'm going to add checking the brake fittings to my annual inspection.
Mike
If the above scenario is correct AND the fittings have now been tightened correctly, they will never loosen up. Checking them will not hurrt anything and there are many things that can be checked. Lug nuts or lug bolts (depending on your trailer age) would be something that does loosen over time even when tightened correctly.
Glad there was no other damage or a single flare fitting used.
Now go camping.
>>>>>>>>>>>>>>Action
Old 06-18-2013, 11:49 AM   #16
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by Jammer View Post
I've always been concerned that aftermarket hydraulic trailer brake systems are underengineered and susceptible to all kinds of non-obvious sources of failure, flexing hoses beyond a safe bend radius, contact wear during suspension movement, and so on.
Are the hydraulic systems on trailers split into two zones as they are on cars?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-18-2013, 12:06 PM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, No.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 06-18-2013, 01:26 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
To expand on the above ... Typically it is no for hydraulic no matter what the actuation method. (There are several)
For electricly applied brakes the answer is sort of. If there is a failure of the wiring or brake at or near the individual wheel the system by design isolates that brake. If the wiring is defective closer to the front of the trailer at some place no braking signal would be delivered at all.
Best remedy for either system is a quick visual on areas that can be seen before dropping the shift lever into D.
>>>>>>>>>>>>>>Action
Old 06-18-2013, 01:44 PM   #19
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Is there any possibility that the brake line is pulling when the suspension is at max travel?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Breakaway brakes Buffalo Brakes & Brake Controllers 5 03-31-2012 06:11 AM
Suburban: Long Down Grade - Tow Mode - Brakes redwoodguy Tow Vehicles 20 12-10-2011 08:21 AM
Almost lost in UTAH Zia On The Road... 39 07-06-2011 09:57 AM
