Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-10-2010, 10:08 AM   #1
1998 30' Excella 1000
HARVEST , Alabama
Lost Brakes, Controller showing Short
98 Excella 31 ft, Lost brakes last evening while traveling, Controller showed short in idle mode, and overload when brakes applied. Dropped at RV repair last evening, repair people unfamiliar with problem. Replaced plug
which I felt was a waste. Has anyone experienced this problem and if so
where was the short, in wiring or wheel?
njansen is offline   Reply With Quote
Old 08-10-2010, 10:26 AM   #2
hohne's Avatar
My brand-new 2004 safari 28W had an intermittent short that became a quasi-permanent short. A wire had come loose inside one of the wheels and was hitting ground most of the time.
Had it into the mothership twice -- they found it the second time. The second time the technician and I drove my truck with two brake controllers installed as that is what they blamed the first time. They then towed it with their F250 and it also showed the short, exonerating my truck and all the wiring and electronics. He found it right away the second time.
hohne is offline   Reply With Quote
Old 08-10-2010, 11:38 AM   #3
HARVEST , Alabama
RE: Lost Brakes
Thanks for reply, repair place found problem, magnet in left rear brake fried. Springs broke, in process of replacing brake parts and shoes in
left side, right side in good condition. I have a lot of miles on thid unit
so guess its about time to experience problems.
Old 08-10-2010, 12:47 PM   #4
hohne's Avatar
Good they found it -- those pesky brake parts...
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
Lost trailer brakes - Help! airhead Brakes & Brake Controllers 4 05-20-2009 10:52 PM
Lost Trailer Brakes This Weekend DEITZ645 Brakes & Brake Controllers 26 05-16-2009 04:43 PM
Disc Brakes and Break Controller Air Apparent Brakes & Brake Controllers 0 04-30-2009 07:24 PM
Brake controller for disc brakes dickschaak Hitches, Couplers & Balls 4 04-19-2009 05:27 PM
